Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Rebuild Of The ParkZone T-28 W/ Crash Video...
Reply
Old 09-07-2013, 02:49 AM
Boostedpower
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Rebuild Of The ParkZone T-28 W/ Crash Video...
Hey guys, new to online RC threads, but that being said I had a little misfortune while trying to get some good OnBoard footage from the top of the rudder angle, anyways you can watch for yourself, but I did a nice low pass (girlfriend is recording) and after that I go up to do a barrel roll (there is another body of water so I thought it would look cool) and just over half way though the canopy comes off!! But the worst was yet to come. It hit the Horizontal stab ripping it off! Not only that but it was the side with the control arm. watch the video for what happens next. (http://www.youtube.com/watch?v=52H7kqeLoAs) If you listen closely on the low pass you can hear the plastic coating they use dragging. This being the second ParkZone T-28 I have had elevator issues (lack of support and thickness) I decided to try an fix it, which required boiling the fuselage (http://youtu.be/aWry69x2xEs ) I then used some 20min epoxy, Pliers (to break to size), and Popsicle sticks to fix the landing gear, which originally broke from this ( http://www.youtube.com/watch?v=y_cpDlhPJ94 from using an older heavy camcorder) and after repaired without Popsicle sticks this happened after one touch and go.... ( http://www.youtube.com/watch?v=TKqoXBCapDk ) ........
So after the crash into the lake I am left with this....
1. Fuselage/Motor Mount/ Front Landing Gear...
155 by boostedpower, on Flickr
154 by boostedpower, on Flickr
And here is the "Official" cause of the crash....
160 by boostedpower, on Flickr
Boostedpower is offline
Old 09-07-2013, 03:08 AM
Boostedpower
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So Here is what I did to fix it, sorry, no more videos...
1. Went to HomeDepot and got some solid foam board, Then went to the work shop and got some shaping tools (a foam cutter would have been ideal, however I did not have one handy)
368 by boostedpower, on Flickr
2. Traced, with a forgiving margin and used the full size razor blade to cut, this took some time. But ended up with this. -->
369 by boostedpower, on Flickr
370 by boostedpower, on Flickr
372 by boostedpower, on Flickr
3. Then Tons of sanding! from a flat hand sander ($3) ---> (almost not yet!) --->
402 by boostedpower, on Flickr
3. THEN URIKIA!--->
406 by boostedpower, on Flickr
BUT! Only the front half, and to fit the new elevator control surface It's going to require a little modification (cutting away) to the fuselage.--->
405 by boostedpower, on Flickr
Old 09-07-2013, 03:25 AM
Boostedpower
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Now that the the front half of the stabilizer is in place. Here is a Comparison of thickness from the new modified one(pink) compared to the stock one(white) --->
408 by boostedpower, on Flickr
425 by boostedpower, on Flickr
435 by boostedpower, on Flickr
Then I cut away a little bit of each side so make room for the newer, thicker Control surface...
442 by boostedpower, on Flickr
Making room for everything to come together (rough draft, no hinges yet)...
444 by boostedpower, on Flickr
447 by boostedpower, on Flickr
Then Time For Hinges!
459 by boostedpower, on Flickr
460 by boostedpower, on Flickr
Then, The inevitable happened... A piece of foam that wasn't supposed to break off, Did....
462 by boostedpower, on Flickr
A little 20min Epoxy later....
463 by boostedpower, on Flickr
465 by boostedpower, on Flickr
Old 09-07-2013, 03:32 AM
Boostedpower
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the plane...
467 by boostedpower, on Flickr
put a little Scotch tape on as support for the hinges, added a few slits with a razor after to improve movement..
469 by boostedpower, on Flickr
474 by boostedpower, on Flickr
494 by boostedpower, on Flickr
For test purposes...
491 by boostedpower, on Flickr
And paint for another day, want to see how well this works and bring some thin sandpaper for parts that are rubbing before paint! Let me know what you guys think!
Old 09-07-2013, 04:02 AM
Boostedpower
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And as far as the landing gear failure, fix, crash, and then rebuild, I have done this for reinforcement so that NEVER happens again, because grass and apparently tracks with grip will tear the landing gear to shreds...
483 by boostedpower, on Flickr
Popsicle sticks broken with needle nose pliers and two seprate coats of 20min Epoxy... First coat is to fill cracks, second is to fill and coat.... *Note: I removed the front landing gear and top piece secured buy two screws to keep any moving parts from seizing*
478 by boostedpower, on Flickr
480 by boostedpower, on Flickr
484 by boostedpower, on Flickr
This One Came Out UGLYYYY!! But it is Solid as they come!
479 by boostedpower, on Flickr
Undertail...
481 by boostedpower, on Flickr
Reply
Display Modes
