If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 1 of 4 123 ... LastLast
Results 1 to 25 of 83
  1. #1
    ctshepherd's Avatar
    Join Date
    Mar 2002
    Durham, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Aeroworks 50CC Mustang Rebuild
    I picked up this Mustang from a flier in North Carolina after it had suffered a wing mounting dowel failure. The fuselage bore the brunt of the damage. Wing is in good condition except for the trailing edge where the mounting bolts were located. I traced out all of the parts that I could and will cut them out of the wood that just arrived today.
    Here is how she looked after the crash...
    Click image for larger version.
ID:	1944832Click image for larger version.
    I made templates of the formers, servo and equipment mounting trays and of the "good" fuselage side so I can cut new parts for those that were obliterated in the crash.
ID:	1944835Click image for larger version.
    My wood order arrived today from National Balsa, took them a while to get it to me but the quality looks good for the 1/8" Balsa and lite ply. Also had them ship some triangle stock and 1/8" dowel for reinforcing the rebuilt motor box.
    Since I had some free time, I went ahead and started cutting out the replacement fuselage side and motor box parts from the 1/8" ply. I still need to cut out the right side for the motor box, it is a duplicate of the left just being a tad shorter to account for the built in engine thrust. Lightening holes still need to be cut out as well.
    I had previously been working on the wing and here are a couple of closeups of the damage done the trailing edge where the bolts ripped out. I will cut the damaged area out and splice in some new hardwood that will be tied into the remaining hardwood block. Once everything is repaired, the top of the wing will be fiberglassed.
ID:	1944839Click image for larger version.
    This pic shows where I cut out the damaged areas and the new hardwood blocks that I have cut to shape to match the wing profile.
ID:	1944841 Click image for larger version.
    When the wing departed the fuselage, the servo wires and air lines damaged some of the sheeting. I have removed the damaged areas and will replace.
ID:	1944843Click image for larger version.
    And that is pretty much where I am at right now. I have ordered a new cowling, canopy, cockpit kit and radiator scoop from Aeroworks. I will need to wait until that stuff arrives so I can use the cowling to get the outline for the formers that turned to dust in the crash. The fiberglass wing fillets are pretty messed up as well, but they are not available as replacement parts so I will probably need to go the evercoat route and make them myself.
  2. #2
    Join Date
    Jan 2003
    Belleville, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Good Job!
    Keep up the good work, I look forward to the next series of photos.
    It's Time to Kick the Tires and Light the Fires!
  3. #3
    hookedonrc's Avatar
    Join Date
    Dec 2002
    Tulsa, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Same with me, I am interested in the process too. We can all take lessons in reconstruction techniques. Although I have built in the past, I am tending toward the ARF types now. Rebuilding a crashed plane is a good way to keep in practice. Well not that I crash a lot......
    Will add something clever and witty if I ever come up with something.
  4. #4
    irocbsa's Avatar
    Join Date
    Apr 2009
    Ann Arbor, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Keep the updates coming. I'm sure we can all learn something.
  5. #5
    ctshepherd's Avatar
    Join Date
    Mar 2002
    Durham, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I was able to get a little more done this afternoon after work. I finished cutting out all of the lightening and tab holes on the replacement ply parts. I am reusing the firewall as it was not damaged from the crash and it is already drilled for the engine that I will be using, which is a DLE 55. You will notice the dremel with a drill bit, I used this to widen the slot holes in the motor box sides as I was test fitting it together.
    Test fitting the motor box pieces together...
    Motor box assembled dry, not a bad fit. All of the inside corners will have triangle stock and the firewall will be pinned when I get around to gluing it all together.
    With the motor box looking pretty good, I set it aside and turned my attention to the fuselage. The front of the left fuselage side looks a little rough as the picture shows. I will replace the broken parts and probably back it on the inside with 1/16 ply. The outside will be sheeted with 1/8 balsa. Second picture shows the new plywood piece that will take the place of the damaged section and the third picture shows the new piece laying over top of the damaged section.
ID:	1945093Click image for larger version.
ID:	1945094Click image for larger version.
    I then mocked up the new right fuselage side to see how things lined up. The sheeting that is on the side that is still present will be cut back to the line as noted by the marker. This will allow the new 1/8" sheeting that will be applied to the fuselage side to be staggered and add strength. I will use some fiberglass cloth over this joint prior to applying the new sheeting. Triangle stock will be added to the inside joint at this former for additional strength.
    That is it for tonight. There are still a couple of formers that need to be cut, but those are waiting on the cowl to arrive so I can get the correct radius. Those formers did not survive the crash.
  6. #6
    ctshepherd's Avatar
    Join Date
    Mar 2002
    Durham, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    While I am waiting on the parts from Aeroworks, I decided to do some work on the wing.
    I started by replacing the damaged sheeting on the center section by putting some 1/8" balsa as a lip so that the new sheeting would have something to glue to.
    I then cut and fitted the new sheeting. Filler will be applied to any gaps present, final sanded and then fiberglass cloth applied. I will then use a forstner bit to drill the holes to allow the air lines and servo extensions to pass through.
ID:	1945406Click image for larger version.
    It was then time to turn my attention to replacing the trailing edge that was damaged by the wing bolts. The original trailing edge wing mount was not actually hardwood, but really dense balsa sandwiched by the balsa sheeting. I am replacing this with hardwood that will be tied into the existing structure with 1/4" carbon fiber rods. Gorilla glue is used and after it has set, I will cut and frame out the necessary pieces to square off the trailing edge. The damaged parts are a good source for these pieces.. :-) First picture is of the carbon fiber rods, second is my "depth gauge" on the drill. I drilled two holes in both the trailing edge and hardwood block and liberally applied Gorilla glue and the third picture shows the block attached with just a hint of the glue foaming. Once all of the pieces are attached, filled, and sanded, I will apply fiberglass cloth for added strength.
ID:	1945411Click image for larger version.
ID:	1945412Click image for larger version.
    That is it for tonight...
  7. #7
    ctshepherd's Avatar
    Join Date
    Mar 2002
    Durham, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Decided to do a little more work on the Mustang as it is a rainy and cold day here in North Carolina...
    First thing I did was cut out the replacement cowling mounting tabs, there are six of these tabs needed.
    I then decided to replace the damaged front section on the left fuselage side. First photo shows where I marked the damaged area to be cut off. I used a dremel with a cut off wheel. Second photo shows me hold the replacement piece from behind the side to mark where it would need to be cut. Third photo shows the 1/16" ply doubler to go over the joint and the fourth photo shows the repaired piece.
ID:	1945883Click image for larger version.
ID:	1945884Click image for larger version.
ID:	1945885Click image for larger version.
    The repaired left front fuselage side.
    As you can see, I have attached the replacement right side. The top of that side is 1/16" lower than the left because someone did not measure the wood on the left side correctly! The balsa stick on the left side is 1/4 x 5/16 and the replacement balsa stick that I ordered is 1/4 x 1/4. I will just have to sand the left side down a 1/16" so everything matches.
    Now, just waiting on the stuff from Aeroworks arrive on Wednesday so I can get the dimensions from the cowl to cut out the two remaining formers that turned into dust from the crash.
    The replacement wing hold block is looking good, nice and strong. Needs a few pieces of balsa to build out the length on the trailing edge to match up to the fuselage. Pictures on that next time.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  8. #8
    ctshepherd's Avatar
    Join Date
    Mar 2002
    Durham, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Now, just waiting on the stuff from Aeroworks to arrive on Wednesday so I can get the dimensions from the cowl to cut out the two remaining formers that turned into dust from the crash.
  9. #9
    ctshepherd's Avatar
    Join Date
    Mar 2002
    Durham, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Not sure how I got a duplicate posting... I can't figure out how to delete one of them. Oh well.
  10. #10
    Fly2XS's Avatar
    Join Date
    May 2005
    Eden Prairie, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How are you looking to finish your Mustang?
    Monocote? Glass? Paint?
    Color scheme?
    Scott: AMA L628, RCCA #108
    Westland Lysander - ugly airplane fan!
    F4U 'Corsair' Brotherhood #49
    P-40 'Warhawk' Brotherhood #103
    P-47 'Jug' Brotherhood #124
  11. #11
    ctshepherd's Avatar
    Join Date
    Mar 2002
    Durham, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Scott,
    I am going to stick with Ultracote for this one. I don't have the space and equipment to do glass and a paint job. Scheme is going to be Petie 3rd. I'm taking inspiration from Tom Bell's Mustang in the second picture on what can be done with Ultracote, panel lines, rivets, and airbrushed weathering.
  12. #12
    ctshepherd's Avatar
    Join Date
    Mar 2002
    Durham, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cowling, canopy, cockpit and radiator scoop arrived today.
ID:	1946634Click image for larger version.
    Inside of the cowling was a nice piece of cardboard which I used to make the template to cut out the former that ties the motor box to the fuselage sides. Note -- the inside of the cardboard was not precut, I measured the motor box that I had cut out previously and then cut it out.
    The former fitted to the motor box
    The new motor box and former mocked up on the fuselage.
ID:	1946638Click image for larger version.
ID:	1946639Click image for larger version.
    At this point I flipped the fuselage over and set the wing in the saddle in order to get the proper profile for the front wing hold down former. I will add a sub-former on each of these formers that are recessed 1/8" and notched to accept 1/4" square stock. That will then be sheeted.
    Making good progress....
  13. #13
    hookedonrc's Avatar
    Join Date
    Dec 2002
    Tulsa, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I think you are understating your progress... To me it looks that amazing progress. I would still be trying to figure out where to start. Very very good work.
  14. #14
    ctshepherd's Avatar
    Join Date
    Mar 2002
    Durham, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks -- it has taken a lot of thinking and looking at pictures of assembled Aeroworks Mustangs to try and see how everything was originally was put together. I think I have a pretty good grasp on how it should go back together. Just takes a lot of template making, fitting and trimming to get things to fit correctly.
  15. #15
    ctshepherd's Avatar
    Join Date
    Mar 2002
    Durham, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Progress continues, although at a little slower pace. It is a bit chilly in the garage! Anyway, I have attached the interior former to the back of the motor box and test fitted into the fuselage as shown in the pictures below.
ID:	1947523Click image for larger version.
    I glued in the doublers and notched them for the 1/4" x 1/4" square stock that the bottom sheeting will go over.
    I then flipped everything over and set the canopy and windshield in place so that I could get the proper height of the former that is needed to provide support for the windshield.
    I have not glued the new motor box to the fuselage yet as I still have some reinforcing to do with triangle stock on the corners. I ran out of triangle stock, so I will have to pick up some more. Also need some more 1/4" square stock for the top stringers that will run from the windshield to the firewall former. This last picture shows how everything is coming together.
    Until next time...
  16. #16
    ctshepherd's Avatar
    Join Date
    Mar 2002
    Durham, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Anyone out there?...
    Did a little more work today on the cockpit area rebuilding the sides that were missing. From the pictures of the windshield that I have seen I am not that excited with the factory method of the windshield mounting on top of the sheeting. I am going to try and have the windshield to be flush with the surrounding sheeting.
    This pic shows how the factory method has the windshield mounting on top of the sheeting... do not like.
    Canopy rails have been mocked up and tack glued in place. Cockpit sides and instrument panel test fit.
ID:	1947741Click image for larger version.
    Just had to get a picture with the cowling in place. It is starting to look like a P-51 again.
ID:	1947743Click image for larger version.
  17. #17
    ctshepherd's Avatar
    Join Date
    Mar 2002
    Durham, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Some inspiration shots...
ID:	1948049Click image for larger version.
ID:	1948050Click image for larger version.
    I installed the cowling mounting tabs today and now I am just waiting on fiberglass cloth and more triangle and square stock. Once I have that, I can permanently glue the motor box to the fuselage and work on sheeting the fuselage.
  18. #18
    hookedonrc's Avatar
    Join Date
    Dec 2002
    Tulsa, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Very very nice. From where it started, you have done a masterful job of reconstruction. It may have already been covered, but did you improve the wing attachment method? After all, it's what caused the problems in the first place.
  19. #19
    ctshepherd's Avatar
    Join Date
    Mar 2002
    Durham, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I don't plan on redesigning the front hold down method as it will work perfectly fine as designed as long as there is some glue on the dowels to prevent them from slipping back into the wing. I was surprised that the wings did not have an internal stop built in to prevent the dowels from sliding back into the wing??
    This pic shows how the wing dowels were when I obtained the airplane. One was completely missing and the other is almost flush with the front of the wing.
Name:	wing mount dowels.JPG
  20. #20
    foodstick's Avatar
    Join Date
    Mar 2005
    ankeny, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ctshepard you are doing a great job, I have done a few rebuilds myself and I think you are not shy about hard work ! One thing I would have suggested if I had been there and seen what you are doing. I don't know if that airframe will need any nose weight? but I think I would have been tempted to cut two new front sides from lite ply, and not even drilled any lightening holes in them. I think you could have made it stronger , easier, and barely heavier. I guarantee it would still fly well. This is in NO WAY meant as a criticism, it is just another route that might have been easier with no bad effects.
    Keep up the good work it is obvious you have a good hand on construction, I will be happy to see that bird in the air ! I am actually trying to repair an abandoned Nosen P51 at the moment. I have yet to pick a paint scheme, I like the one you are going with...
  21. #21
    ctshepherd's Avatar
    Join Date
    Mar 2002
    Durham, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Foodstick, thanks for the reply. I won't know if the airframe will need nose weight until I get everything back together and engine mounted, etc. Planning on picking up some more materials in the next couple of days to continue work on it.
  22. #22
    ctshepherd's Avatar
    Join Date
    Mar 2002
    Durham, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Continuing work on the Mustang... I've got the top stringers and air tank former in place. Started fitting the sheeting on the left side of the fuselage. Coming along nicely.
ID:	1949950Click image for larger version.
ID:	1949951Click image for larger version.
ID:	1949952Click image for larger version.
ID:	1949953Click image for larger version.
ID:	1949954Click image for larger version.
ID:	1949955Click image for larger version.
ID:	1949956Click image for larger version.
ID:	1949957Click image for larger version.
ID:	1949958Click image for larger version.
  23. #23
    hookedonrc's Avatar
    Join Date
    Dec 2002
    Tulsa, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I like the use of binder clips as clamps for the sheeting, but do have a question. Don't they leave impressions of the clamp in the balsa?
  24. #24
    ctshepherd's Avatar
    Join Date
    Mar 2002
    Durham, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The binder clips will leave impressions on soft balsa. The top sheeting that I used is very hard. Clamps are in very short supply in my shop. I need to stop at a Northern Tool or Harbor Freight and stock up.
  25. #25
    Join Date
    Jun 2004
    WILLIAMSTON, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Quote Originally Posted by ctshepherd View Post
    Slide a scrap of 1/8 ply between binder clip and work until you go shoping
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
