Go Back  RCU Forums > RC Airplanes > Crash & Rebuild
Reload this Page > My first repair job - Tailplane & rudder rebuild
Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Reply
Old 12-06-2013, 07:28 AM
carl24bpool
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default My first repair job - Tailplane & rudder rebuild
I've been flying now for around 6 months and I did build a Precendent Hi Boy when I was 16 albeit very poorly as I still have it now.
Recently I saw a Black Horse Travel Air on Ebay with an Irvine 53 (red bottom) engine, all servos and a futaba micro 35mhz receiver. I paid 21 for the lot. I think that's around $30 over the pond. Quite a bargain I thought.the only catch being that the rudder was smashed and so was the horizontal on one side. Here's the Ebay pic. Sorry I don't have any of my own:
as you can see the damage is as described. For what the plane cost I felt I had done well just getting what I did for such a small amount.
So I began the rebuild of the tailplane by cutting it away until I had some clean edges to work with:
I then built a new rudder and used some images from the internet to judge how big the overhang was at the top of the rudder.
I didn't want to try removing the tail entirely as this may cause further damage to the structure as the cut outs where it slots in seem very fragile. That and it may not go in square again.
So I decided the rear joint could be spliced together but the front join was right against the fuse so I had to think of another method. I decided to use some bamboo skewer to form a dowel which would give me the strong join I needed. So I built the missing section again from scratch by tracing the other side and drawing it out on a building board. I then cut it at the join areas so that when joined to the fuse it would be the same size as the other side:
After a bit of glue the horizontal was back on:
I then covered the rudder and horizontal before refitting the elevator and rudder. It was then ready to go:
Unfortunately during the test flight there was a total loss of control resulting in a nasty crash:
I'll start a new thread on the rebuild. lol.
carl24bpool is offline
Old 12-06-2013, 08:12 AM
hookedonrc
hookedonrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well at least the tail survived. Sorry about the loss of control...any idea what might have been the cause?....Never mind, I just read your other thread.
hookedonrc is offline
Contact Us Archive Advertising Cookie Policy
