Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Great Planes Revolver 70 Rebuild!!
Reply
Old 05-16-2017, 05:38 PM
el_xero
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Lets hinge it up!
Some shots of the robart hinge job. It wasn't super great but it worked like it should have. Though I do have one a tiny bit loose now. aaaanyway.
ID:	2215574   Click image for larger version
ID:	2215575   Click image for larger version
ID:	2215576   Click image for larger version
ID:	2215577   Click image for larger version
ID:	2215578   Click image for larger version
ID:	2215579   Click image for larger version
ID:	2215580   Click image for larger version
ID:	2215582   Click image for larger version
ID:	2215583   Click image for larger version
ID:	2215584   Click image for larger version
el_xero is offline
Old 05-16-2017, 05:49 PM
el_xero
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Servos and horns?
I'm not using the XQ Power servos displayed here anymore. Those had to be send back, rather, I used Hitech's but these pics detail my install process. I took some tips from others in other posts and applied them here. Also The control horns pictured aren't the final ones used in my setup. I didn't trust these for anything other than pull.. I couldn't get my self to feel confortable using them in a push configuration so I wen't with more traditional horns. I'll upload pics of those later on.
ID:	2215586   Click image for larger version
ID:	2215587   Click image for larger version
ID:	2215588   Click image for larger version
ID:	2215589   Click image for larger version
ID:	2215590   Click image for larger version
ID:	2215591   Click image for larger version
ID:	2215592   Click image for larger version
ID:	2215594   Click image for larger version
ID:	2215595   Click image for larger version
ID:	2215596   Click image for larger version
ID:	2215597   Click image for larger version
ID:	2215598   Click image for larger version
ID:	2215599   Click image for larger version
ID:	2215600   Click image for larger version
ID:	2215602   Click image for larger version
ID:	2215603   Click image for larger version
ID:	2215604   Click image for larger version
ID:	2215605   Click image for larger version
ID:	2215606   Click image for larger version
ID:	2215607   Click image for larger version
ID:	2215608   Click image for larger version
ID:	2215610   Click image for larger version
el_xero is offline
Old 05-16-2017, 06:02 PM
el_xero
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Ignition
Did up a hack job for my ignition. I tried using a micro servo thinking I would save weight? The thing burnt up after literally one run so I ended up using a regular servo, I didn't go for those fancy opto kill switches etc...
Maybe later I'll go for that who knows.
ID:	2215612   Click image for larger version
ID:	2215613   Click image for larger version
ID:	2215614   Click image for larger version
ID:	2215615   Click image for larger version
ID:	2215616   Click image for larger version
ID:	2215617   Click image for larger version
ID:	2215618   Click image for larger version
ID:	2215620   Click image for larger version
ID:	2215621   Click image for larger version
ID:	2215622   Click image for larger version
ID:	2215623   Click image for larger version
ID:	2215624   Click image for larger version
ID:	2215625   Click image for larger version
el_xero is offline
Old 05-16-2017, 06:14 PM
el_xero
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Covering Finally!
Alright! So it's almost time for the home run! Lets cover it all up! New paint scheme as you've likely already gathered I'm ripping off the scheme fromt he 50cc revolver and I'm not in the least bit ashamed of it ha
ID:	2215627   Click image for larger version
ID:	2215628   Click image for larger version
ID:	2215629   Click image for larger version
ID:	2215630   Click image for larger version
ID:	2215631   Click image for larger version
ID:	2215632   Click image for larger version
ID:	2215633   Click image for larger version
ID:	2215635   Click image for larger version
ID:	2215636   Click image for larger version
ID:	2215637   Click image for larger version
ID:	2215638   Click image for larger version
ID:	2215639   Click image for larger version
ID:	2215640   Click image for larger version
ID:	2215641   Click image for larger version
ID:	2215643   Click image for larger version
ID:	2215644   Click image for larger version
ID:	2215645   Click image for larger version
ID:	2215646   Click image for larger version
ID:	2215647   Click image for larger version
ID:	2215648   Click image for larger version
ID:	2215649   Click image for larger version
ID:	2215651   Click image for larger version
ID:	2215652   Click image for larger version
ID:	2215653   Click image for larger version
ID:	2215654   Click image for larger version
ID:	2215655   Click image for larger version
ID:	2215656   Click image for larger version
ID:	2215657   Click image for larger version
ID:	2215659   Click image for larger version
ID:	2215660   Click image for larger version
ID:	2215661   Click image for larger version
ID:	2215662   Click image for larger version
ID:	2215663   Click image for larger version
ID:	2215664   Click image for larger version
ID:	2215665   Click image for larger version
el_xero is offline
Old 05-16-2017, 06:26 PM
el_xero
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default A bit of setting up?
Almost just nearly there. Here's a teeny bit of setting up.
ID:	2215667   Click image for larger version
ID:	2215668   Click image for larger version
ID:	2215669   Click image for larger version
ID:	2215670   Click image for larger version
ID:	2215671   Click image for larger version
ID:	2215672   Click image for larger version
ID:	2215673   Click image for larger version
ID:	2215675   Click image for larger version
ID:	2215676   Click image for larger version
ID:	2215677   Click image for larger version
ID:	2215678   Click image for larger version
ID:	2215679   Click image for larger version
ID:	2215680   Click image for larger version
ID:	2215681   Click image for larger version
ID:	2215683   Click image for larger version
ID:	2215684   Click image for larger version
ID:	2215685   Click image for larger version
ID:	2215686   Click image for larger version
ID:	2215687   Click image for larger version
ID:	2215688   Click image for larger version
ID:	2215689   Click image for larger version
ID:	2215691   Click image for larger version
ID:	2215692   Click image for larger version
ID:	2215693   Click image for larger version
ID:	2215694   Click image for larger version
ID:	2215695   Click image for larger version
ID:	2215696   Click image for larger version
ID:	2215697   Click image for larger version
el_xero is offline
Old 05-16-2017, 06:35 PM
  #31
el_xero
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Ready to fly!
That's it folks! All done and ready to fly. I'm sorry I don't have many still's left of the plane for posing time. However I do have some flight videos.
Next up, I'll be editing those and uploading. I'll post links of those flights soon as I can hopefully by the end of this week.
I hope everyone enjoyed this journey. I know it was a lot of pics and chatter. Hopefully it was worth it for you all.
Have a great week and thanks for checking out my thread.
ID:	2215706   Click image for larger version
ID:	2215707   Click image for larger version
ID:	2215708   Click image for larger version
ID:	2215709   Click image for larger version
el_xero is offline
Old 05-16-2017, 10:36 PM
  #32
el_xero
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Flight Videos
Well I can't sleep so decided to edit some videos.
Not sure if this is the remaiden or not but here's something to look at. Apologies for the quality guys. It can't be helped
el_xero is offline
Old 05-16-2017, 10:56 PM
  #33
el_xero
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Flight video 2
Here's one more andd a third one on the way
el_xero is offline
Old 05-16-2017, 11:37 PM
  #34
el_xero
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Video 3
Here's the last one for tonight. Broken xoar. Better the prop than the plane right? haha
I think I have maybe two more videos to upload. Maybe tomorrow. Till next time guys.
el_xero is offline
Old 05-25-2017, 12:17 AM
  #35
jescardin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Inspiring great job!
Congrats for the rebuilt.
Best Regards
jescardin is offline
Old 05-28-2017, 04:15 PM
  #36
el_xero
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Thanks
Best Regards
Thanks, I only did minimal work though mostly the wing and the canopy. The heavy lifting was done by a friend and mentor.
I'm glad you enjoyed the thread thanks for checking it out.
el_xero is offline
Old 10-03-2017, 02:35 PM
  #37
cjbotox
cjbotox's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Absolutely AWESOME - both labor and finish. Back in the day when I started in RC (1988) we ALWAYS repaired our planes no matter how wiped out they were. We also built ALL of them, some from scratch. This is a very good thread and I congratulate you and your friend for this inspirational labor of love. Nowadays it's too easy to just throw away the wreckage and grab a new one. I had to rebuild the front engine mount compartment on my R70 and now I'm looking for a kit to build something!
BTW - how did you fair through Irma?
John
cjbotox is offline
Old 10-08-2017, 05:35 PM
  #38
el_xero
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John
Hi John Thanks so much for the support man really appreciate it! Sorry that I'm so late in replying I've not been on RCU in a while. Over here we mostly have to repair out planes and such because getting stuff over here is just insanely expensive. Think of the cost and then just multiply by 5 that's what we'd pay in our currency for stuff we import over here but as you said It's about the love for all things RC and building so much as it's work we keep at it and rebuild when we have to Thanks for checking out the thread, It took me forever to get around to put it up and when I finally got a high speed connection I just went for it! I'm glad you enjoyed it! How's your flying going? Do you have any posts I can check out?
We're doing great over here Irma didn't hit us but a few of the other islands aren't looking great at all
el_xero is offline
Old 10-10-2017, 05:40 AM
  #39
cjbotox
cjbotox's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't know if you remember me from over on the other thread 'Larger Revolver' trying out the Hobby Eagle gyro (under cjbotox). Somewhere I happened to find reference to your rebuild thread here, and read through it. Very interesting and inspiring to me as I am getting back to kit and scratch building. My Revolver is still flying, albeit changed in appearance and weight. I'm loosing interest in it because I've had to fix more bugs in this plane then all the others put together. One of my flying buddies lives on a small lake and float flying is getting the best of us.
I'll be keeping in touch...
John
cjbotox is offline
Old 10-10-2017, 04:12 PM
  #40
el_xero
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thumbs up
John
Hi again
It's been a while since I scanned through the other larger revolver thread. I think I'll have go jump back on and give it a read again. I'm sure to remember you once I do
Floats!!!! I envy you! I'd love to try that some time! Be sure to document and start a thread or feel free to upload stuff on here if you like. I really don't mind.
I'd love to get into scratch building some day, No time these days not to mention the materials. I'd try to copy this revolver and make some changes for sure!
I don't blame you for moving on to an other bird.
For me though this is literally the nicest looking one I've ever owned (I'm also partial to my GP dazzler which I recently gave away *quite the looker that one ha*) but I want to move out of glow and do strictly bigger gas planes. It think the biggest I'm going to go is 30cc ....some day ha.
Speaking of the Dazzler, if you're interested you can find the build thread right here (she's really pretty if I do say so my self!)
My very first Kit!
Let me know what you think!
Oh snap! You said gyro! You're the dude who put the gyro on the revolver?!!!
Yes yes I remember that post! haha
I've definitely got to go back and read that thread again!
el_xero is offline
