Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Thrust angle
Reply
Old 10-11-2018, 05:38 PM
lamarkeiko
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Thrust angle
Damaged engine box
New engine mount box
I'm rebuilding a damaged nose on a Great Planes Revolver 60. I've built a new engine box that attaches to the first bulk head. I'd like to know if I need to have some engine thrust angle built in, or just ensure my prop shaft is centered to the cowl.
Lamar
lamarkeiko is offline
Old 10-12-2018, 07:06 AM
All Day Dan
All Day Dan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lamar, IF no one really knows from experience, start out with zero and trim from there. Dan.
All Day Dan is offline
Old 10-12-2018, 03:42 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would put 1.5 degrees right thrust into it and go from there.
speedracerntrixie is offline
Old 10-12-2018, 04:46 PM
lamarkeiko
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the reply back. I was thinking I might need some right thrust. How do you go about measuring 1.5 degree thrust? Is the first bulkhead used as a reference point?
Lamar
Old 10-12-2018, 05:16 PM
r ward
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if you can put a straight edge across the bulkhead that the engine mount is bolted to, center the straight edge on the mid point of that bulkhead and measure from the ends of the straight edge back to the tail of the fuselage. same measurement means the bulk head has no offset. shorter measurement is direction bulkhead is offset to for thrust angle. if offset is present,...shorter measurement should be right side looking from the tail of the plane.
with a 12 inch straight edge , 1-1/2 degrees should be a difference in measurement of about 5/16 - 3/8 inch.
r ward is offline
Old 10-12-2018, 05:23 PM
speedracerntrixie
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Offset the engine to the left 1/4" and then center the shaft in the cowl. That will get you really close. It doesn't take much right thrust to help keep the airplane straight during take off runs. The other consideration for right thrust is to keep up lines straight but precision aerobatics is not really in the Revolvers wheel house.
