Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
How far to sand
Reply
Old 01-28-2019, 06:04 PM
Ozzy37
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default How far to sand
So my 4 * 40 got some hangar rash on the last 3 inches of the horizontal stab. Gonna replace the horizontal/vertical stabs plus the elevator and rudder. Question is how far down into lite ply that forms the base that the horizontal stab rests on should I have to sand to get back to a glue able surface. Originally I glued it with 30 minute epoxy? Any guess out there?
Ozzy37 is offline
Old 01-28-2019, 06:48 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would suggest removing all the old epoxy. A heat gun and an xacto chisel blade works really well for epoxy removal.
speedracerntrixie is offline
Old 01-29-2019, 04:54 AM
Appowner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I rarely use epoxy in the tail and when/if I do, I use it sparingly. Adds too much weight. But since you already have it in there, just take the epoxy down to the top layer of the wood. There will still be epoxy in the wood grain but that's OK. The important thing is the platform is smooth, straight and properly aligned. Then use epoxy sparingly when gluing the new piece in. And if possible, clamp it.
Appowner is online now
Old 01-29-2019, 07:25 AM
mgnostic
mgnostic's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1 on Appowner's comment. Two things to look for are a stable surface for gluing and proper alignment of the part. Getting back to the top layer of wood will do that. Sanding with a coarser grit may be your friend here since if the wood grain is sealed with old epoxy this will provide more tooth for the glue to bind to. At times where this has been a concern I have even stippled the gluing surface with a pin to make small holes for the glue to wick into.
mgnostic is offline
Old 01-29-2019, 07:58 AM
pkoury
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I second this suggestion. I have used heat to release epoxy joints on several aircraft rebuild/restorations. I will use either a heat gun or covering iron to warm the epoxy releasing the glue joint. A quick wipe with a paper towel and alcohol usually leaves a glue ready surface.
pkoury is offline
