Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Crash Investigation help request
Reply
Old 09-10-2019, 06:24 AM
SteelonSteel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Crash Investigation help request
I have a new albeit wrinkled Tower Hobbies Hellcat. It comes as a PNP and I added a Lemon plus stabilizer.
Two other mods I thought were minor. I replaced the tiger connector with a XT60 and added more neodymium magnetsto hold the front cowl on.
The first flight started nice, needed an elevator trim adjustment but was flyable. Flew two circuits and a mock landing approach. Flying to start my downwind leg I was level and in a shallow climb and she throttled back on her own and I lost control of it.....gliding to a uncontrolled stall at the trees. Broken prop and some mild rash.
My lemon antennas didn’t stay apart and laid straight aft along the aileron wires. I figured maybe they got masked and lost signal. New MAS prop, taped the antennas in separate places, rearranged the aileron wires away from them.
Tested ok on the ground with a range check. Took off after rechecking control surfaces. Long takeoff roll on purpose, pulled right upon command. Got about 25feet up and powered fully in a steep dive no apparent response.
At this point all i can hypothesize is a bad receiver, a bad solder joint on the ESC or the extra magnets in the cowl are messing something up.
SteelonSteel is offline
Old 09-10-2019, 01:47 PM
Maurice Pudlo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would go over the stabilizer setup, and turn it off until you are a few mistakes high.
Obviously check and adjust balance and servo throws.
I would Imagine the weight difference shouldn't put you outside of a wing loading that would prevent flight but consider doing a few glide tests over a soft surface.
I don't think the connector swap would be an issue assuming the job was done correctly.
You can open up the reciever and look for burnt components, cracked/melted/just not right traces and solder joints.
Similarly so with other electrical components such as speed control, the stabilizer, servos etc.
Lastly, if you are using exceptionally underpowered servos that stall at the control surface deflections you are asking them to perform...that can be an issue that is outside my ability to explain, I use an online calculator to see if my servos have enough torque to do the job I'm asking of them.
Maurice Pudlo
Maurice Pudlo is offline
Old 09-10-2019, 04:55 PM
SteelonSteel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for putting your thoughts to it.
I wasn’t thinking the weight of the magnets was an issue, I still had to add stick on lead wheel weights to balance on the correct CG. I was thinking those super strong magnets might affect the electronics, they are still 5 inches from the receiver but only a couple from the ESC.
i am a new rc flyer, so I don’t know what I don’t know.
ETA I tugged on the solder wires, they seemed sound. I did redo it as I didn’t like the first connection as my solder in the connector got a bit cold and it stuck early not fully inserted. That was before any flight though.
Old 09-14-2019, 06:33 AM
jester_s1
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'd go with it being a bad receiver or faulty transmitter. Lemon stuff does work, but there is no quality control. You are the final inspector, so to speak. It really should be done with every receiver, but particular with cheap ones- an extended range test with motor/engine vibration and at all possible angles. This is where telemetry radios have such an advantage, because you can not only see if it works, but can count glitches and maybe even know the actual signal strength.
jester_s1 is offline
