Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
aw poop!
Old 11-10-2003, 12:00 PM
stuffer
stuffer's Avatar
Default aw poop!
well, here is a good tip...when you program an aircraft over another aircraft on your radio...either deactivate switches not used or erase the program completly! 1 ea Giles 202 stuffed due to old program on an accidently activated switch. oops! []
Old 11-11-2003, 12:54 PM
DBCherry
Default RE: aw poop!
Yep. Always best to return that "aircraft" in the radio to the factory default settings before doing anything else.
Dennis-
