Is this vibration normal???
My Feedback: (20)
NC
I just started the first four stroke I've ever owned. The engine, a OS FS70 is mounted in a U-Can-Do 46 that I just built (99% finished). When I ran the engine, only about a half tank, the plane vibrated so much that it almost hurt to hold on to it. It wasn't severe enough to make the plane move or anything, but it was very high pitched vibration... almost like it could make your spine raddle. Is that normal??? It feels like it could shake the whole plane apart. Also, it stalled after approximately 5 min, and was so HOT!!! is that normal either? Am I missing something here? Like I said, this is my first four stroke, and don't know a lot about them. I've been handling two strokes for 20 years, and can't remember anything like this... Help anyone???
My Feedback: (7)
CA
RE: Is this vibration normal???
I would think that due to your long years of two stroke flying that tuning would obvious for you, so my next question would be was the plane assembled when you ran the engine(wings on)? The wings help damped the vibration of a four stroke. As for the heat, it sounds like it was lean, that would also cause it to hit so hard to shake the plane. I hope that the prop and spinner were balanced too. [8D]
My Feedback: (20)
NC
Well, yes... lean would explain the heat I guess. I was actually running through the 'break in procedures' going back and forth between rich and lean. Now that I think about it, I think the prop and spinner balancing probably had a lot to do with it. It was pretty difficult getting the prop and spinner to fit on the engine.
