Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
GP Lancair wing failure
Reply
Old 10-06-2005, 09:39 AM
  #76
davidsai
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: GP Lancair wing failure
does any one now what are the time and date setting on the forum i se this crazy times and was just wondering
davidsai is offline
Old 10-06-2005, 11:24 AM
  #77
davidsai
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
By the way Eric what is the air tempereature where you fly here is between 28 and 32 degress celcius at sea level
david
davidsai is offline
Old 10-09-2005, 06:32 AM
  #78
jetmech05
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sorry about your loss im not here to say you glued what to what or didn't glue what to what.
as rc flying goes airplanes get retired or wind up in the trash.
i am not a crash fan but they happen
with that in mind a wing failure in flight makes a great crash.
go out with a flash of glory looks like that is exactly what you did
keep flying have fun everyone
jetmech05 is offline
Old 10-14-2005, 04:19 PM
  #79
EBHolmes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi David,
That's pretty much the same temperature range that I fly in during the summer. I'm also roughly at sea level. If you are still having over-heating problems after you increase the cooling air exit area at the rear of the cowl around the nose gear, try flying with a little richer fuel mixture. Max out the RPM's on the ground and then richen the mixture until the RPMs drop by a 200. See if that solves your problem. What nitro content are you using? I have used 10% and 15% with good success.
-Eric
EBHolmes is offline
Old 10-15-2005, 10:14 AM
  #80
davidsai
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Eric good morning
I am using 0 nitro but tomorrow will try with some 3 % more or less of nitro hard to come by around here
te engine is not overheating on pit try outs will see what happens tomorrow.
have a nice weekend
regards
david
www.cybul.com
davidsai is offline
Old 10-18-2005, 10:02 AM
  #81
davidsai
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well guys finally flew the lancair on sunday
made 3 flights all of them went well great landings a bit bumpy the last oone but no problems
made some slow loops and rolls the engine did not quit eventhough the air temp was 32 degrees celcius
it tended to climb but some down elevator fixed that it is balanced a bit heavier on the nose so i guess is just elevator positioning problem
the landing gear work fine did not bend or anything of the sort,
flys strait and true and lands perfectly evethough it takes a long run on the tarmac for it to stop
any way great flying soon videos at www.cybul.com/rcguide.html
regards
david
davidsai is offline
Old 10-18-2005, 10:18 AM
  #82
frank99
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
have been watching the posts on the lancair, great news on the flight, and have pulled mine out of the coner of the garage, the plane had a lot of pilots in it a huge wasp nest ,under the fin[X(] now how to get them out serria front landing gear came in HAS ANY ONE GOT A PIC OF THE INSTALL AND WHEEL PANTS INSTALL, off to wal mart to get some bug spray and get this aircraft in the air engine os 91 4c wing center carbon fiber and glassed, making a plate to go over the landing gear, have i left any thing out thanks frank
frank99 is offline
Old 06-24-2017, 07:46 AM
  #83
Mr._Bean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Thank you
12 years later I bring this thread back to life!
Recently picked up a never used GP Lancair ES 60. It was in storage for many years. Had some hangar rash to touch up, but overall in very nice condition.
Found this old thread and the info on the weak wing joint. I have stripped the covering on the wing center section, added an aluminum wing halve joiner (epoxied/screwed) and then attached the 2 piece landing gear to this joiner. Then I added 4" wide fiberglass around the entire wing center (including the aluminum joiner), section. I hope that this mod, along with flying the aircraft in a scale fashion (not high G aerobatics), will be sufficient to enjoy this beautiful bird for a long time!
I've also replaced the nose gear.
Thank you to the OP for the info, and for the helpful comments on how to correct this design flaw. Appreciated.
It's powered by a Tower .75.
Anyone still flying this plane?
Anyone? anyone? Bueller? Bueller?
Mr._Bean is offline
Old 10-24-2017, 10:24 AM
  #84
ricardobowe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Found one turned into my local hobby shop.
I recently found one and am considering electrifying it. Will cut out and hinge the door so I can add batteries. Looking at a Power 90 motor for this bird. Will reinforce the wings if I do buy it
ricardobowe is offline
Old 03-14-2018, 12:36 PM
  #85
stang151
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have had three of these Lancairs , all with the same Super Tigre .75 in them. The first had many flights , and a few "hard landings" , and finally cracked the fuse. so bad that I decided to replace it. The second had about 35 flights on it when I put it in from an inverted flat spin. The third and present one has about 15 flights on it ,I am kinda babying it as there are not many around. Still have the wings of the two first planes.The tips are cracked and gear broken out but no problems with join. All three were glassed on assembly,on the last I added some carbon fiber strips out past the gear cutouts. I might add that I flew all of these pretty hard. I do like this plane and it really impresses coming down in a knife edge spin.
stang151 is offline
Old 03-14-2018, 12:50 PM
  #86
stang151
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Couple of pics of wing #3.
ID:	2259207   Click image for larger version
stang151 is offline
