Cub crash/video
CA
Cub crash/video
Pilot forgot to switch transmitter to this plane...ailerons were reversed......
http://home.dc.rr.com/maurie/PiperSplat.wmv
RE: Cub crash/video
i was going to say the same thing normally with the airlerons reversed something like that would happen right after take off not half way through a pattern
My Feedback: (32)
RE: Cub crash/video
I'm wondering if the second hard pullup didn't weaken the wing center joint and the only thing that was holding the wing was the strut. Airspeed was there so either that or pilot error on the right stick started the roll. Trim may have also been way off since at takeoff it appears it wanted to roll right to begin with and he may have been trimming it the wrong way which did no good since the ailerons were reversed
RE: Cub crash/video
Sorry to hear another Baby Bear went in. I always check my ailerons before every flight, as well as everything else. My oldest son once got his ailerons reversed, but was quick minded enough to go ahead and proceed through the entire flight without making a correction. I guess that's why he and his yonger brother always beat me a video games! Rebuild it and fly it again...and check the ailerons before flight. Good luck.
"Keep 'Em Flying!"
Flak
"Keep 'Em Flying!"
Flak
My Feedback: (192)
TX
RE: Cub crash/video
ORIGINAL: Flyboy Dave
It was doing fine, straight and level....then it went down and then started
spinning....it almost looked like the pilot stuffed it....rather than the ailerons
reversed.
FBD. []
reversed.
FBD. []
ON, CANADA
RE: Cub crash/video
Level flight, full throttle dive followed by violent rolls.....
I'd say the aircraft reached VNE and something let go causeing asymetrical drag.
My Feedback: (51)
RE: Cub crash/video
Great video! I loved the added sound effects. I heard nobody complaining about reversed controls during the flight though. Looked like he just lost it(dumb thumbed) to me, and it didn't seem like he even throttled it back after the loss of control. My guess is when it porpose dived down he had to much throw in the elevator when trying to correct it, and it snapped. The result was turning a good Plane to pencil shavings!
My Feedback: (51)
RE: Cub crash/video
I also wanted to add that if you watch the slow motion portion of the video you will notice that the plane snaps just as he reaches the bottom of the dive, and tries to pull up. You will see the Plane coming out of the dive for a split second before it snaps, and rolls. It had nothing to do with aileron inputs. Also givin the fact that the dive put him at a very low attitude, it offered him little time to react by backing off the throttle, and switching to low rates if he was indeed flying on high rates. This is just my opinion, but from the video it does seem obvious that the problem was not with the ailerons.
RE: Cub crash/video
Haha...make this event as a lesson learnt...i too one didnt check my flight controls for my maiden plane and juz flew...my elevator was reversed =S lucky i could get it down...
Worst still, my fren forgotten to pull out his antenna...nv do such mistakes again =)
