Prop Bitten
#227
One thing I do, not foolproof, but an extra is that all switches on the tx are in the rear position when I plug in a battery or go to a glow model. One switch in that position takes the throttle curve to zero in all throttle positions. The intent is only when restrained or ready to fly does that switch move forward, giving control to the throttle.
Too bad it happened but thank you very much for letting us know. I will be more cautious at least for awhile.
#229
Just to show you all that rc people aren't the only ones that can destroy flesh and bone.
The story goes that that this guy tried to take the nut out of a deep wall socket with his finger while it was still attached to the impact tool.
Notice the especially painfull threads across the first joint and up the second bone of the finger.
Since I'm only 30 yr engineer and not a doctor I'd love to see the tool used to remove this "nut".
What is the best guess?? Dremel tool? 4 1/2 in grinder and cut off wheel? How about a 'nut breaker'? They might have had to get a dentist with his assortment of drills and grinders. haha
#233
I've almost been prop bitten. I had a friend setting up my first plane, we hooked up the battery and the plane jumped forward after the receiver connected. Turns out the throttle channel was reversed in the radio. We got lucky and all it did was rip the plastic cover off the antenna on the radio. He was quick to move the stick, but had I done this myself, i'm wiling to bet there would've been more damage. Now anytime I work on it the prop comes off.
#234
Much of this carnage also depends on the type of materials that the props are made from. This is why metal props are pretty much banned in most/if not all clubs. Carbon blades are pretty much just as strong. Next are those glass props and then the wooden ones. Wood tends to break before it does too much damage (smaller scale prop sizes anyways).
#236
Originally Posted by [email protected]
People who don't think electrics are dangerous obviously never had one. In my opinion, more dangerous than IC airplanes. Almost learned the hard way more than once.
I've had a finger or two come in contact with props on my planes before, not often but has happened before. Sure it hurt but nothing like what the images on this thread show happened to others. This is so in part because I've never got my hands in the prop of an engine larger than .65 and always ran wooden props along with never getting it in a prop that was moving at FOT.
I read somewhere that the below damage was caused by a metal prop:
http://www.youtube.com/watch?v=tzXyYX7hZvw
#237
Steve is right! Electrics can start just by energizing the the power system with the radio on. An electric motor can go to full power in an instant. I have several small electrics I have built and love the heck out of them but I try to use extreme caution when hooking the battery up and turning on the radio. A lot of guys are installing arming plugs and a rubber band on the throttle stick on the transmitter. It's just good safety. I have been fortunate my only propeller strikes have been from .020 and .049 engines and 40 years later I STILL have the scars. I shudder to think what a larger prop would have done.
#238
That's the thing with electrics. Ya plug it in, carry it over to the line, your checking something when you bump the throttle stick by accident, and WHAMO! Happens that quick. You never see it coming and you always said " how can someone let that happen to themselves?" Then it's you. And trust me, these electrics don't stop when you catch a finger in it, they just keep chewing and chewing until you stop feeding them. My accident was with a K&B 61 with a glass prop. Could have been much worse, but still missed half a month of work and spent 5 months in PT.BE CAREFUL BECAUSE IT CAN HAPPEN TO YOU TOO!!!
#239
that's the thing with electrics. Ya plug it in, carry it over to the line, your checking something when you bump the throttle stick by accident, and whamo! Happens that quick. You never see it coming and you always said " how can someone let that happen to themselves?" then it's you. And trust me, these electrics don't stop when you catch a finger in it, they just keep chewing and chewing until you stop feeding them. My accident was with a k&b 61 with a glass prop. Could have been much worse, but still missed half a month of work and spent 5 months in pt.be careful because it can happen to you too!!!
#240
Another problems with electrics, is when setting up or switching between models. You may think you are at low throttle when it is actually full throttle, as the direction is reversed. You may even be using an arming plug and when you complete the circuit, off it goes.
Also, I think that since most electrics are lightweight they can lurch so quickly. It can be on a table one second, and in your face the next.
#241
#242
#243
Pay attention to detail. Doing so will prevent most, if not all of these issues. Also your club should have protocol on where electrics can and cannot be energized. Simply on a table is not allowed in most club airfields. They can only be energized in the pit where glow engines are only allowed to be started and ran, with proper restraints being utilized, just like the glow and plug planes. Even though they are electric, most, if not all clubs consider an energized plane the same as a running glow or plug plane and needs to be handled accordingly.
#244
I couldn't agree more. But, I'm sure it's the same at most fields, there's always that one guy who probably shouldn't be flying anymore, either old age, or inexperience, or both.seen it happen, and seen guys told there no longer welcome, to much risk.kinda sad when they been flying that field for 50+ years.
#246
Multiples of sadness, especially before 2.4 was available.
#247
Dennis
#249
Wow, that's a first.never heard of anyone taking such drastic measures.
