toughlon and monokote
Has anyone tried monokote and toughlon together? I have a solid color machII. I want to cut some of the toughlon covering off and put on monokote. Just wondering if it will seal to each other.
RE: toughlon and monokote
ORIGINAL: antique opa
I am familiar with Toughlon. I have had a few World model birds. The Toughlon will melt and adversly deform at the temperature you need to get monocoat to shrink to fit. The Monocoat will stick and seal befor the Toughlon melts but if you need to shrink the monocoat any nearby toughlon will be ruined. The toughlon will start falling off soon enough so you might as well strip the bird now and just cover it all with monocoat.
My Feedback: (26)
Monokote also has a trim solvent that works pretty good if you are careful with it. Too much and you end up with a gooey mess. Ive applied Monokote over Monokote using only Windex to bond them. After squeezing out the air bubbles, run a Q-tip dipped in trim solvent along the edges and youre good to go.
I used windex. Iput monokote over the toughlon. I took out all the bubbles, then let dry. Went back the next day and sealed the edge with a trim iron. Worked great.
