broken muffler
NJ
broken muffler
Hi All
I have a Slimline Pitts style muffler, that the exhaust pipes have broken lose from the muffler..Both me and a friend have the same problem..We both tried JB weld without any luck..Any thoughts and suggestion will be greatly appericated..Is there a product that works on gluing aluminum..
Thanks Dan
Thanks Dan
RE: broken muffler
JB Weld will work AND works well.
THOROUGHLY clean the area AND parts TWICE using acetone and clean cloths EACH TIME.
Now apply the JB Weld (the regular, not the quick stuff) and let dry.
I have a couple of mufflers (and engines ) repaired with JB Weld and they hold up very well. The key to success is making sure the area is thoroughly clean.
NJ
RE: broken muffler
Flytaildragger: you said:Send it back to the manufacturer, I did on my slimline and they replaced it.. Good company...
Would they replace the muffler even if I crashed the plane it was in??
Thanks Dan
Thanks Dan
RE: broken muffler
ORIGINAL: DBono99
Hi All
Thanks Dan
Hi All
Thanks Dan
A guy named Dan, at my airfield in Wisconsin, lost a pipe on his pitts muffler Saturday as well. He was lucky, I saw it come off. It was at the end of the short grass, and I went out and managed to find it... he said he'd try to Tig it back on...
