Please help me I need help...
NY
I bought a saito 125 thAT HAS A stripped glow plug hole. Was supposed to be a perfect engine and I find this. Quite mad about it. I just want it fixed very quickly the right way.
I found a place in connecticut that does this and fixes engines. I cannot find it and qqould love it soneone knows what I am talking about.
I can send it to CA but shipping costs and time is just to much and to long. I am NY so Connecticut is perfect. I would really appredciate your help. I have been have some really bad past few days. I finally got to fly today and found this. Kind of depressed me. Something has to go right some time...
IA
RE: Please help me I need help...
Fellers, sorry I can't be of MORE help, but I think a gent by the name of Clarence Lee may be of help. I suspect you can find him VIA Goggle search.
Best of luck, Dan
Best of luck, Dan
My Feedback: (159)
Hello, I can empithize with you. I have had my share of BAD LUCK with Radio Systems!! I crashed my last two planes, both on the same day due to radio problems!! Both planes were a TOTAL LOSE, and so was 1 engine. I went out and purchased another transmitter and that didn't work either, I sent it in for repairs but I am not sure of it. I still do not have a reliable system. Well Christmas is on the way, Maybe Santa will bring me one??
Well to answer your need, I did a search on RCU Forums and came up with the following two people that do repairs on stripped heads. One is the one in Cal. the other one I do beleive is the one you are looking for in Connecticut. I have personally dealt with BJ'S and and Bill is GREAT!!! I hope this is helpful! Best of Luck
Happy Holidays
Nevin M. Levy
G17Staggerwing
Status: Stripped Glow Plug threads.
Send head only
C. F. Lee Mfg. Co
10112 Woodward AVE
Sunland, CA 91040
818 352 3766
For repairs on Model Engines.
BJ's Model Engine Service
Bill Jensen
36 Macintosh Dr.
Oxford, CT 06478
203 888 4819
www.starcomposites.com/BJModelEngines
_____________________________
MO
Fella's would a heli coil work. I know on stripped bolt holes on cars they work great. You can get them at just about any parts store. You just drill the hole a smidgen bigger screw the heli coil in and wala you got a new bolt hole. I think it might work. The heli coil kits are cheap also. And they tell you what size to drill your hole for each size heli coil. Ask at a parts store they probabaly can tell you. Just a thought. And what i would try first. If it don't work your not out but a few dollars and then you still can have them fixed if it don't work. My bet is that it will work. Just don't know for sure if they go that small but sure would not hurt to ask. Less than 10.00. And you can do it your self with a drill that is all that is needed. NAPA man ask him or any of them. HELI COIL KIT
My Feedback: (159)
\Hello Steve
A helicoil would work, BUT you would have to get one that fit the glow plug thread. Which is as was previously stated on the prior post a very uncommon one. The threat size needed for a glow plug is 1/4-32. If you come up with anyone that has that type of threaded helicoil please post it.
Regards
Nevin
G17Staggerwing
Regards
Nevin
G17Staggerwing
CA
I had the same thing with my saito. It had stripped glow plug threads. I sent mine in and they fixed it. It is best to send it in and let them do it because is will cover it under warrenty. Helicoil will void the warrenty, so I wouldn't bother doing that. And it could also cause leaks. My .02
My Feedback: (10)
I bought my helicoil kit a while back and was able to reclaim the cost by doing repairs for the LHS. The tap and inserts get spendy pretty quick. The average guy with one or two engines would most likely be able to get a new engine for what a kit cost these days.
