Go Back  RCU Forums > RC Airplanes > Crash & Rebuild
Reload this Page >
I don't like it. I think I'll retire it. *WAM*
Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Reply
Old 03-11-2002, 11:22 PM
visioneer_one
My Feedback: (506)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default I don't like it. I think I'll retire it. *WAM*
I had a Global Sukhoi. Very pretty, but really too heavy to be an excellent flyer.
It also had some balance issues. During one of its recent outings the bloody thing tried to kill me! (story posted right here in the Hangar Hangout forum. Read it - or you won't know what the Gap is. )
I brought it out this weekend, determined to sort it out . I rechecked the balance and control throws, did another range test and checked the structure. All OK.
Fueled up, fired up and away we go. Similar problems as before - it still seems to be nose heavy and has a disappointing roll rate. No 3D with this one - just big smooth pattern-type maneuvers. Won't spin. Drops the left wing in uplines. Snaprolls are nice, though.
A few minutes into the flight and I'm kvetching away. "This thing has never flown right. I'm not real happy with it - maybe I should pull the gear out and build something else. I wouldn't want to sell it to anyone 'cause it flies like *expletive-starting-with-"ess"-deleted*"
Ah well. If pattern-type maneuvers are what this thing is good for, so be it. Can't disappoint the spectators - we had a couple of visitors.
(rolls and loops) (high speed passes) (sloppy pseudo-3D maneuvers)
I was setting up a low (and slow) pass through the Gap. I went way downwind, rolled inverted, lined up with the Gap and started slowing her down.
(The engine dies. I can't hear it over the 10-knot wind)
(the YS .53 is very quiet at low throttle!)
Slower, slower. Wups! Too slow... add a little throttle. OK, a little more throttle. Hey! The prop isn't moving.
"Deadstick!"
I flipped it over and tried to make it back to the field. As I had bled off most of my airspeed while inverted, I knew it wasn't going to be easy... I was too low and far out to dive. Plus I had to attempt to avoid the Tree in the Gap...
I held the wings level and slightly nose-low. I couldn't climb over the tree, but perhaps I could steer around it! Rudder only, don't want to tipstall it.
FAP! thud! thud!
I clipped a branch of the Tree In The Gap with my left wing. The firewall (with engine and cowl still attached) flew off and the rest of the plane spun to the ground flat.
Feh.
All the gear survived 100% intact. Even the throttle servo! This is one time I was glad that I used the brittle wire the ARF manufacturer supplied - the throttle wire snapped off clean when the firewall went its own way.
Our resident web-guy was there that day, but forgot his camera at home! You are all spared a photo of yr. fthfl. authr. holding a cowl/engine/firewall/fueltank module in one hand, a fuselage & wing (still attached - and all the servos still wiggle) in the other.
The plane is repairable, but I've decided to retire it. The replacement is on order - a Morris Top Cap. Seems like I remember reading somewhere thats supposed to be a pretty good 3D airframe. )
visioneer_one is offline
Old 03-12-2002, 03:28 AM
JohnVH
My Feedback: (38)
JohnVH's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
haha, good choice for a new toy! Too bad about that plane
JohnVH is offline
Old 03-12-2002, 04:25 AM
visioneer_one
My Feedback: (506)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default the CULPRIT
I just finished tearing down the plane. The main clunk line has stretched out and was contacting the bottom-back of the tank. When I rolled and held inverted the poor engine was just sucking air... which explains the flameout.
Old 03-12-2002, 07:23 AM
Timbersnake
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
See that? I told you guys that a crash forum would be entertaining AND educational.
My sympathy to ya visioneer...but it doesn't look like you're going to lose much sleep....
Some of the best flying I've ever done has come after I've decided that all of the gear in the current airframe was coming at the end of the day...one way or another.
TM
Timbersnake is offline
Old 03-15-2002, 03:36 AM
irad8u
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default plane eating trees
I was flying for the first time at a new field. There are 2 trees at the end of the runway. WAY on the other end. Lining up for a landing, I thought I was on this side of the trees, however, full throttle I nose up and get visualization of my plane, I nose down and lower throttle. Lose sight of my plane again. full throttle and nose up then a small visualization of the plane just before I hear SNAP, POP, CRASH, BAMM, and then a dead silence. Do you know the way a wing "flutters" when it is detatched from the fuselage? That's what both of them were doing. I stood in amazement and then about 10 seconds later, I hear and see the fuselage barrelling down from limb to limb. I felt like Charlie Brown with his kites and the kite eating trees. Remember that? anyways, here's a pic.
irad8u is offline
