Go Back  RCU Forums > RC Airplanes > Crash & Rebuild
Reload this Page >
Hanger 9 Easy Fly 40 C.G. HELP
Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Old 02-26-2009, 01:11 AM
dragnova
Default Hanger 9 Easy Fly 40 C.G. HELP
I have a easy fly 40 that i got in 4th grade i am 22 now and i just starter flying it 6 mounth ago sadly i never replaced the TX battery and the E-Servo reversed and i went into the ground and i now started rebulding it all most done i did some mods on it added flaps and putting floats on it with a Magnum XL-70RFS 4-Stroke the only thing i need is the C.G. and i cant seem to find my manual Any help would be appreciated
Old 02-26-2009, 07:48 AM
RC MANIAC119
My Feedback: (14)
Default RE: Hanger 9 Easy Fly 40 C.G. HELP
I'm assuming that your Easy Fly 40 is a top wing model.....but that dosen't matter. Your C/G should be very close to the thickest part, OR FORWARD, of your main wing..and this can usually be easily achieved by moving your RX battery around.
Remember.....Nose Heavy Good.......TAIL HEAVY BAAAAAAD!!!
Old 02-27-2009, 03:46 PM
dragnova
thank you do you have any hints for flying with floats
Old 02-27-2009, 08:15 PM
rustypep
CG on the Easy Fly 40 was 3 1/4 from the leading edge. Good luck!
Old 02-27-2009, 11:08 PM
dragnova
thank very much
