Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Extreme Flight Extra 300 50cc /Not rebuildable video
Reply
Old 03-26-2009, 11:24 PM
nitro wing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Extreme Flight Extra 300 50cc /Not rebuildable video
This was on flight #2
Cause,possible water interference in electronics (suspect,unconfirmed) under investigation
History: 23 years performance aircraft,low crash ratio.
Build 65+ ,lost 10 + due to high risk or equipment failure.Some put in by pilot
This was wrong,Aircraft checked out.Gear tested in other airframe
http://www.youtube.com/watch?v=h00mgg8QfCM
ID:	1166948   Click image for larger version
nitro wing is offline
Old 03-27-2009, 07:25 AM
RC MANIAC119
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Extreme Flight Extra 300 50cc /Not rebuildable video
I feel your pain Bro.......[&o]
RC MANIAC119 is offline
Old 03-27-2009, 08:50 AM
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Something you never get use to seeing, YUK!!!!
FlyerInOKC is offline
Old 03-27-2009, 09:43 AM
krayzc-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
those tarus engines sure do run oh so smooth
krayzc-RCU is offline
Old 03-27-2009, 11:46 AM
daveopam
Moderator
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That stinks! At least you did not dumb thumb it. You would have felt worse had it been your fault.
David
daveopam is offline
Old 03-27-2009, 01:21 PM
AA5BY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Look at the video very carefully. Check out the shadow just before he takes off. Unless my eyes are deceiving me, I see a collapsed antenna. Note also in the first flight that the pilot taxis out and around with the antenna collapsed but does of course put it out prior to takeoff. That is a bad habit and may have been the cause of this crash. I've seen several crashes due to collapsed antenna and they fly out just a short way as did this one before control is lost.
I add my sorrow for the loss...
AA5BY is offline
Old 03-27-2009, 02:16 PM
krayzc-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i crashed one time with the ant down as i was pulling it up the plane was going down. in the end i was not clint eastwood on the draw
Old 03-27-2009, 02:22 PM
sir crashallot
sir crashallot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if your correct then a fail safe unit fitted would probably saved it and also give the pilot chance to pull up his antena to regain control, our club has a rule. anything over 75inch wingspan gets a fail safe fitted or it dosnt fly. for the sake of around $40 id do it.
shame to see such a beutiful model crash
sir crashallot is offline
Old 03-27-2009, 03:08 PM
daveopam
Moderator
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can't say yes or no on the ANT being down with that resolution. I would be suprised though if it was out of range that quickly with the ANT down. Didn't look more than a 100' away or so.
David
daveopam is offline
Old 03-27-2009, 04:14 PM
krayzc-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
100' with a down ant is all it takes
Old 03-27-2009, 05:45 PM
AA5BY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The plane looked well over 100' off when he declared a problem. It is also a gasser and typically the receivers suffer a slight degradation of signal from the ignition. My gassers do not range test quite as far with a collapsed antenna as do my glow planes.
Here is a screen capture of the moment the shadow of the antenna seems to be possibly shown.
Again... sorry for the loss of such a beautiful plane that obviously meant a great deal to the owner who had a year of hopes invested in it.
http://pages.suddenlink.net/arlyn/airplanes/antenna.JPG
AA5BY is offline
Old 03-27-2009, 06:02 PM
Live Wire
Live Wire's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would say moisture in the switch or battery failure. The plane stayed in the same attude that it took of in, just like it lost power to the RX. They say to range check at 100' with one section of your ant. up.
Live Wire is offline
Old 03-27-2009, 06:13 PM
sir crashallot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
right i actualy think it was fully extended. theres a long line that could be the ariel and a short one but the sun was to the side of him so you would only get a shadow half the size it should be which would make the ariels shadow look very short.
Old 03-27-2009, 07:33 PM
RC MANIAC119
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think you guys are overlooking the obvious here............that first landing was very wet!! If you slow that video down..(at the landing,) you can see the tons of water that sprayed all over that bird.
My guess is..he got water inside the fuse from that landing! It would only take a few drops in the receiver to cause the interruption of signal.
Old 03-27-2009, 07:42 PM
sir crashallot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well lesson learned, when models in the future are finished put your reciever in a condom. stops any water geting in, i use to do that on rc cars and you should have seen the look when i used to take the cars through big puddles of water and so on
Old 03-27-2009, 07:44 PM
sir crashallot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
secondly he said the radio checked out in another plane if water had got on that reciever with the power of the flight pack he would have had in that then it would most certainly short the reciever and wreck it there and then
Old 03-27-2009, 09:59 PM
AA5BY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
At the crash site, he turns the radio on and says all is working. He seemed to have control up until shortly after initiating a turn downwind. Water in the switch could certainly temporarily short the battery supply and cook dry by the time he checked everything at the crash site.
Looking at the video over and over, the shadow is not convincing to me either way. The video was evidently edited (perhaps for expletives) and might possibly have offered conclusions about the antenna either way.
I agree with Sir... that if the receiver got wet enough to quit, it would probably have fried something and everything worked at the crash pile. If one really wanted to know if a switch getting wet would short out easily, that wouldn't be hard to test.
AA5BY is offline
Old 03-27-2009, 10:34 PM
RC MANIAC119
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well...you guys can speculate all you want. The bottom line is he lost a very expensive airframe, and equiptment, and I'll bet he never fly's off a wet field again!!
Old 03-28-2009, 06:17 AM
SteveW
SteveW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: sir crashallot
I have to respectfully disagree. I have seen all kinds of wet electronics (radios, cell phones, etc.) that came back to life after a careful drying out. And don't ask how they got wet . Not saying that was the problem here but I don't think you can rule it out.
SteveW is offline
Old 03-28-2009, 06:31 AM
sir crashallot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: SteveW
in a plane like that hes not going to have a $20 reciever more like $100 of recieverprobably more though im not quite used to the usd to pound conversion yet, the problem now is when the recievers are more powerful and more expensive they become even more sensative to bangs and damp. i used to mess about with rc cars and iv seen recievers glow bright red and melt with water and a high powered battery pack.
another thing we havent thought about is that with the vibrations of the engine it might have turend the switch off shortly after take off
Old 03-28-2009, 07:07 PM
overbored77
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nitro wing,
Sorry for the loss I have a 50cc almost done and an 85cc in a box, so I know what kind of time and $$ you had invested.
I am not going to speculate what caused your crash because I wasn't there. Please let us know what happened for future reference.
overbored77 is offline
Old 03-29-2009, 12:42 AM
nitro wing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The antenna was up no doubt about it.While I was screaming I looked down and made sure the radio was actually on and antenna out.
I had the antenna down before the first flight because I was range checking during the Taxi,not a bad habit like someone said.
The receiver was far back in the intact section of the fuse,it was not wet or scraped.No water in the fuse either,but alot sprayed into the engine head and spark boot and ignition box.This may have caused
a field of huge radio interference.
The receiver did not loose power and neither did a switch fail. It has an optical kill which would have cut the engine completely in case of a receiver power loss.It just seemed to go out of range and held its position until impact.
I am replacing the Aircraft and engine with an identical unit.
My salvaged radio gear will be test flown in a back up "beater" plane first to make sure its 100% before going into the new Extra.
Old 03-29-2009, 04:31 AM
basman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
NItro wing: glad you have responded it is always good to hear from the horses mouth
I also lost one to what I think may have been a batt lose and disconnecting, total loss of radio: still power to engine no fail safe ( I fly 2.4 ) A typical roockie mistake one with a cost. Unlike you the DL50 survived and maybe some electrics. Ten flights on a rebuild 72" Extra 300xs brand new DL50. I feel your loss[&o][&o][&o][&o][&o]
Picked up a new home for the DL: 77" Edge 540 will start the rebuild soon
basman is offline
Old 03-30-2009, 04:22 PM
djp_9494
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
l hate to watch models going in dude bad luck
djp_9494 is offline
Old 03-30-2009, 09:19 PM
JoeAirPort
JoeAirPort's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nitro, we'll be waiting for you back at the club (EF Extra build thread).
JoeAirPort is offline
Reply
Display Modes
