cowl repair question
i had a slight crash this afternoon and when i landed i stripped the holes on one side of my cowl now the holes are wallered out should or can i fill the holes with something and put them back in the original spot?
MA
RE: cowl repair question
Use micro balloons and 30-minute epoxy to fill in the holes, mixture of about 1 part epoxy mix to 3 parts micro balloons. Sand smooth.
Best to redrill new holes. Then touch up with matching paint.
Or the old-fashioned way, cram toothpicks or toothpick slivers, or better yet slivers of a nice hardwood into the holes with plenty of glue, make sure it's tight, sand smooth, then drill a tiny pilot hole in the same spot.
FL
I understand your post to say, the hole is enlarged on the "cowl",not the plane. I've had good luck using fiberglass resin. Clean the inside & outside of the hole to be repaired. Use alcohol on the outside of the cowl ( should be safe for all paints & decals). Use a piece of masking tape & cover the hole on the "outside of cowl' paying close attention that you really get it to stick firmly. I always will continually rub the tape & get it "warm", that will make it stick around edges of the hole. Then mix a small amount of resin paying attention to not mix it "hot" (too much hardener), lay the area to be filled flat & pour the resin into the hole making sure you get a little" overfill"this will give the resin more area to hold onto, you are pouring this on the inside area of the cowl.. After it's cured, carefully pull off the tape, if you're lucky,all you'll have to do is use a small washer to cover up the repair. At the worst, a little ( very little touch up.) Good luck
TX
If the hole in your cowl is enlarged, try using cowl binders.
http://www.pspmfg.com/CowlBinders.html
My Feedback: (13)
didn't see this posted, so I will add that I epoxy some CA hinge material behind the screw holes, it prevents the holes from opening up even afer a couple of years, my Hangar-9 Mustang cowl started to fail after just a few flights, it was weighed down a bit with Tony Howard exhausts,not alot but the cowl is like paper.
I glued the hinge material in place the cowl is still holding strong.
Has anyone checked out Epo Grip's Model Matrix www.epogrip.com ? Just take a piece if masking tape cover the hole in the cowl and mix up their fiber reinforced material and fill the hole. Drill a new hole and you are finished. Seems they have taken the work out of repairing parts.
