Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
My Stupid F4U Corsair Crash
Reply
Old 09-01-2009, 03:32 PM
jabar145
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default My Stupid F4U Corsair Crash
I just got the F4U Corsair by parkzone a couple days ago. I got a few flights on it, but this morning I forgot to tighten the wing screw enough.
When I was just about finished flying,coming in for my approachat 15 feet, the wing ripped right off the plane! It drove straight into the ground while the wings were still flutteringin the air.
What a shame.
Update- I have now removed all the electronics from the fuselage and am awaiting my parts order. Does the LiPo in the picture look safe to use? It got misshapen in the crash, but not punctured. I am yet to recharge it due to the damages. (It still works fine)
ID:	1267130   Click image for larger version
ID:	1267131   Click image for larger version
ID:	1267132   Click image for larger version
ID:	1267133   Click image for larger version
jabar145 is offline
Old 09-01-2009, 05:49 PM
aerowoof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: My Stupid F4U Corsair Crash
some elmers glue will fix it right up
aerowoof is offline
Old 09-01-2009, 05:57 PM
jabar145
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was going to do that but ended up just ordering a new motor mount, canopy, cowl, batteryand fuselage. I was lucky enough to get a freebrushless motor from Horizion Hobby (Thanks!).
Do you think some epoxy would fix a motor mount and the front of the fuselage?
jabar145 is offline
Old 09-01-2009, 08:11 PM
lejongleur
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Actually I have fixed my PZ Typhoon using Gorilla glue. Once I trashed it to the point of snapping the fuse in half. I gorilla'd it, taped everything tightly until dry, trimmed off the excess glue, and voila! good as new.
lejongleur is offline
Old 09-01-2009, 08:20 PM
speedy72vega
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use 5 min epoxy and clear packing tape, works great also. As far as the mount is concerned, I wouldn't trust glue. They're inexpensive enough to just pick up another one, no sense in risking a good plane to save a few bucks, just my .02 cents.
speedy72vega is offline
Old 09-01-2009, 11:44 PM
lejongleur
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh, absolutely - don't repair an engine mount (the one for yours costs $3.29). I was thinking you wanted to reattach the mount to the front of the damaged foam fuselage, that's why I recommended Gorilla.
Old 09-02-2009, 11:23 AM
shurlock1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah use some elmers glue with some duct tape that will work. If it wont stay together use a hose clamp.
shurlock1 is offline
Old 09-02-2009, 11:24 AM
shurlock1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The propeller is bt the wall you didnt fly it in the house did you?
Old 09-02-2009, 01:41 PM
jabar145
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Haha, no.
That was from my first flight; prop hit the ground and snapped. I just threw it by the wall.
jabar145 is offline
Old 10-13-2009, 03:49 PM
RC Flier
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys, I need some help. My new PZ Corsair is now together and battery charged, but the throttle won't work.......what now?
RC Flier is offline
Old 10-13-2009, 05:29 PM
lejongleur
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Any noises from the ESC when you plug in the battery? If not check the connection between ESC and motor (with the battery OUT of the circuit.) Also, I'm sure you made sure that you turn on the receiver first, set throttle to zero, then power up the plane?
Hope this helps. My apologies if this advice is too simplistic...Chris
Old 10-13-2009, 08:03 PM
speedy72vega
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also, when the plane crashed, did you remember to put the throttle all the way down right away? If not, you might have burned the ESC. When the prop hits the ground and stops, the motor will draw a huge amount of amperage through the ESC if you don't put the throttle down immediately. Can you turn the motor by hand freely?
Old 10-20-2009, 10:55 AM
divelife20
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow that crash sure beats minebut the plane is beautiful! For some of my previous crashes, I've used crazy glue, modeling cement, and packing tape... Depending on how you use it, your plane could turn out good as new.
divelife20 is offline
Old 06-04-2010, 02:31 AM
amc72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow looks like Mine after my crash monday. How'd it come out?
amc72 is offline
Old 06-07-2010, 07:55 PM
hrhodes3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I need a ar500 for my bl mustang .
hrhodes3 is offline
