RCU Forums
-   Crash & Rebuild (https://www.rcuniverse.com/forum/crash-rebuild-96/)
-   -   Curtiss P6E rebuild (https://www.rcuniverse.com/forum/crash-rebuild-96/10831903-curtiss-p6e-rebuild.html)
john comp 11-27-2011 05:11 PM
Curtiss P6E rebuild
Hi for many years I have wanted to rebuild my Scratch built P6E, it was converted to CL and when it was flown the CG wasnt checked, so it Stalled on takeoff, my friend gave it to me to rebuild and I want to put it back to RC. It has a 60"+ wingspan and is 2"=1'-0" scale. The damage is mostly in the engine mount landing gear area. he had a 60 size two stroke nitro engine on it, My question is if you were getting a new motor for it I was told go with a 60 size four stroke for torque and sound, plus a larger prop.
I will post pictures of it as i want it to be a winter project. The other question i have is this plane was covered in silt with dope, probably aerogloss, I have to cut panels out were the servos will go, then recover those areas and try to match the color with available dope of today.
A challenge to be sure, I do have plans for this plane and I know where the CG is, so I'm looking forward to this rebuild.
John
N1EDM 11-27-2011 06:24 PM
RE: Curtiss P6E rebuild
Count me in to lurk on this. An alternative engine might also be a OS 55AX 2-stroke...
Just my $.02
Bob
nitro wing 11-28-2011 08:29 PM
Go 4 stroke, better punch from slow speed and better sound for sure, you may need a .80 - .91 and up to match full output of a good .60 2 stroker. I have no CL experience.
If going RC make it fly true and fun, it does not need lots of power to fly without lines, Enjoy!
F3HDemonDriver 12-14-2011 12:36 PM
ORIGINAL: nitro wing
I agree with Nitro a 4-stroke sounds like a winner! A Curtis P6E a real beauty!http://www.rcuniverse.com/forum/js/f.../msn/heart.gif
<br type="_moz" />
john comp 07-23-2017 03:50 PM
almost there
8 Attachment(s)
For the last two or three months I have been rebuilding my P-6e, after piecing all the small parts together, I thought I had a jig-saw puzzle.
Next came fixing all the holes in the covering, and painting and touching up the original paint scheme. Now were on to installing the radio and servos
then I purchased a OS 70 four stroke and fiber filled mount, after replacing the original hardwood mounts.So today I Ran it in the driveway and she runs great. So the last thing is to assemble her and check the CG.
N1EDM 07-24-2017 05:44 AM
Really glad that you were able to recover from that mishap. Keep us in the loop!!
Bob
john comp 07-24-2017 02:30 PM
first time all together
4 Attachment(s)
Today was the first time she was all assembled, now just waiting for OS exhaust extension, I also think I will leave it assembled, too much work, but well worth it
hope you enjoy, its been a labor of love.
john comp 08-21-2017 03:56 PM
Well the balance is in WOW!
2 Attachment(s)
I assembled the plane, and now trying to balance her I added the weight and am in shock, 2lbs 2 oz to get a nose down attitude.
I am going to try melting the weight to fit under the cowl, another challenge
