Go Back  RCU Forums > RC Helicopters > Draganfly Innovations Products
Reload this Page >
1320 battery size and weight?
Draganfly Innovations Products Discuss all the Draganfly Innovations Products in this forum
Old 10-16-2006, 03:07 PM
13BRV3
Default 1320 battery size and weight?
Greetings again,
Sorry for all the questions, but I'm still trying to sort this all out. If anyone has a DFI 1320 battery pack handy, would you mind measuring it, and weighing it for me?
I've got a number of 11.1V, 2100 mah packs that are 100mm x 30mm x 25mm and 180 grams. Will these fit, and work well with the DF V ti, or are they too big or heavy?
Rusty
Old 10-16-2006, 03:48 PM
Fesfly
Default RE: 1320 battery size and weight?
85 grams, 34x65x20mm for a 1320. Yours should work but may be at the upper limits of weight for the DF causing premature motor failure - others use batteries of the same size without issue. I think you may need a battery connector for the DF as I have read others needed to change them out (not sure).
Old 10-16-2006, 06:39 PM
laceycopter
I've been using 2100 mah packs all summer I have more power and longer flight times. I get about 100 flights on the motors with the 1320's and about 75 on the 2100's, but the flights are much longer.
I will never go back to the 1320's.
Happy Flyin,
Lacey
Old 10-17-2006, 09:25 AM
13BRV3
Thanks for the comments. Very good news about the 2100's
Cheers,
Rusty
