How to reduce jerking produced by your HD motors
Hi everyone I have a radio that allow me to move the points of the throttle curve so what I did in order to reduce the jerking produced by the HD motors was to create a throttle curve as follows:
Stick position 0 2 20 40 60 80 100
Throttle % 0 25 32 49 66 83 100
There are other two ways of reducing jerking.
The first one is to create throttle curves for idle one and two above about throttle at 25% (where jerking disappear) so you initialize your DF in normal mode (idle off and linear throttle curve from 0 to 100), and fly it in idle one or two (Linear or any other type of throttle curves that go from 25 to 100).
The second one is by enabling throttle cut to initialize your DF and disabling it along with a linear throttle curve that goes from 25 to 100 instead of 0 to 100
Hope this helps
Regards
Nick
Hope this helps
Regards
Nick
NC
RE: How to reduce jerking produced by your HD motors
So is there any advantage to the HD motors? If they jerk then I don't think I want them. Has anyone rebuilt the stock motors with a ball bearing case?
GA
ORIGINAL: l8braker
...If they jerk then I don't think I want them. ...
NC
oh man that would suck! I'll stick with my stock motors for now. Maybe I'll find out about ball bearing cans to help it out a little bit.
