RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Draganfly Innovations Products (http://www.rcuniverse.com/forum/draganfly-innovations-products-403/)
-   -   capacitor type? novice question. (http://www.rcuniverse.com/forum/draganfly-innovations-products-403/7986758-capacitor-type-novice-question.html)
Innerbreed 09-24-2008 02:55 PM
Hi all
In regards to the Ceramic Motor Capacitor for filtering electrical noise that are currently issue with the Draganflyer v ti.
SKU: DF-MOTORCAP
I am looking for the specifacations on these, and would very much apreciate your help in finding out the following..
Lead Pitch, Capacitance Tolerance, Voltage, Capacitance, and Manufacturer.
Any information you can give me would be helpful.
Ragards,
Jonny Poole.
Innerbreed 09-29-2008 11:04 AM
RE: capacitor type? novice question.
i know that If you put 12 volt capacitor into a 24 volt circuit, all you will get out is 12 volts. but what would be the out come of putting a 24 volt cap on a 12 volt circuit? would this work on the DF motors as i have loads of them lying about.
va3mw 10-10-2008 08:12 PM
The 12V is the maximum rating that the capacitor can work with. So, as long as it is higher than 12V, that is fine. Now, if you put a 6V cap on it, you get to see what happens when capacitors explode!
.01uF capacitors are the cockroach of electronic parts. ;) They are used EVERYWHERE. As long as you get close when replacing it, that is fine.
Mike
Innerbreed 10-11-2008 04:09 AM
yeah i have completed my project now, after a bit of research. DF flying fine now. thank you.
