Jett 56lx / 60lx question
I'm considering the Jett 60lx for a current project and someone had said they thought the 60lx was replaced by the 56lx. Is there any truth to this?
My Feedback: (57)
IN
RE: Jett 56lx / 60lx question
Not according to http://jettengineering.com/
The current engines all end in zero.
My Feedback: (57)
IN
OK, based on the dates at the bottom of each webpage on the Jett site, it doesn't look like he even has a webmaster, let alone someone who updates it on a regular basis.
My Feedback: (19)
OH
Hi,
Thanks for writing......
YEs, that is accurate. The 60LX has been discontinued, and replaced with the .56LX
My apologies, the website is a lightyear out of date. (my project, need to get it done)
The .56LX is the same size, weight, and performance as the 60LX. Very user friendly.... and amazing versitility on prop selection.
There are a few build projects in the extreme speed section that use the SJ-56LX ..... worth taking a look.
Sorry for the confusion!
Bob
Bob
My Feedback: (19)
OH
ORIGINAL: ThumbSkull
ORIGINAL: bob27s
Hi,
Bob
Hi,
Bob
Two other side questions - why was the 60 replaced by the 56? and If I buy a Jett Stream muffler to run on my TT .46, will that same muffler bolt up to a side exhaust .56lx?
My Feedback: (19)
OH
The 56LX is just the new generation engine. It is based off the "longer stroke" racing engines... longer rod. Just performs a lot better all around.
The Jett-Stream muffler will turn at TT46 into a real animal. Amazing how the engine reacts. Good way to start.
The Jett and OS/TT type muffler bolt spacing is different. Jett matches ST and Webra. But jett-stream tuned mufflers are available for OS/TT and all other engines.
ORIGINAL: bob27s
The 56LX is just the new generation engine. It is based off the ''longer stroke'' racing engines... longer rod. Just performs a lot better all around.
Thanks for your help.
ORIGINAL: 1QwkSport2.5r
If I went to the 56LX, I'd want a full wave tuned pipe on it anyway now that I think about it.
ORIGINAL: vasek
IMHO there's no need for a long pipe with Jett engines. The tuned muffler is the ''optimal'' option if you consider full pipe weight & install. The engines run pretty well on the tuned muffler.
ORIGINAL: vasek
Hi 1Q,
The 1/4 wave muffler has been tuned by Dub to a specific engine, you can't tune it better that that IMO!
Hi 1Q,
Nevermind on the last post. I'm pretty much going to plan on getting a Rear exhaust .56lx with a full wave pipe. I just need to know - is there a cost difference between the ABC or AAC versions? Can you turn the same RPMS with an AAC as you can with an ABC?
My Feedback: (19)
OH
performance from AAC and ABC are about the same. AAC tends to be lighter.
Typically AAC cost a little more.
Rear exhaust with a full pipe is the maximum performance. But keep in mind - RPM is relative to the load. You will have to decide a bit ahead of time what size prop you wish to run. The pipe will be tuned for an RPM range (fairly narrow on a full pipe). Once set up your prop selection has to keep the engine in that range to run its best.
Bob
Bob
ORIGINAL: bob27s
Bob
Bob
