Dub Jett Engines Support Bob Brassel of Dub Jett Engines provides direct support here for Jett Engines.
Engine shafts?for Jett 56
Reply
Old 05-27-2011, 02:44 AM
richardgerardi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Engine shafts?for Jett 56
I just got the 56 Jett. I was installing a spinner and noticed that the shaft came loose. I also noticed that there was a second one in the bag which is longer. The question is is the normal for it to come loose and how do you tighten it? Thanks
richardgerardi is offline
Old 05-31-2011, 06:56 PM
still4given
still4given's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Engine shafts?for Jett 56
You typically thread them in until they stop and then back it out a turn. Install the prop and tighten. This way, if there is a crash and the threaded stud breaks off you can simply remove what's left and install a new one.
still4given is offline
Old 06-07-2011, 06:55 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for helping.
Yes, install it loose. Thread it in a minimum of 3/8", but do not bottom it out. You can use this as an adjustment if needed for spinner/prop fit.
If you tighten it, the threaded stud can get askew slightly you will not see it, but the prop might mis-align. You want the prop stud to float in the threads a bit, and the prop will square up properly on the drive washer.
Bob
bob27s is offline
Old 06-08-2011, 10:38 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob,
Not to hijack a thread, but I have a related question - on my SJ .50 and on a couple of my OPS engines with prop studs, I cut a small (1/16") washer of silicone fuel tubing and drop this into the crank before threading in the prop stud. My thinking - perhaps misguided - is that this would give me a soft stop for the stud and be a good indicator that I had threaded it in good and far but not too far. I screw the stud up to the silicone but only until it touches with light finger pressure. It is enough of a stop that the friction of the prop nut won't tighten it any further.
Is there any logic to this? Bad/good idea?
MJD
MJD is offline
Old 06-11-2011, 11:38 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds like a reasonable proceedure.
bob27s is offline
