Pitts Style Muffler
My Feedback: (19)
OH
Pitts Style Muffler
Hi, thanks for writing.
Our primary recommendation is our own Turbo-Jett muffler. The compact in-cowl design, provides the best performance with a SJ-50. The SJ-50 is a fairly high-timed engine, and although performance with the in-cowl design (RPM) is slightly lower than when using the standard Jett-Stream muffler, it does gains a significant performance boost with the Turbo-Jett.
http://www.jettengineering.com/accy/turbo.html
You can find dimensions for each size on the web page.
I have a SJ-46 with a turbo-jett running in my VQ P-51 Mustang, and the installation was a near perfect fit within the cowling. There are photos of a P-47, AT-6, and GeeBee on the Hall of Fame page
http://www.jettengineering.com/hall/index.html
and also of a Zero on the turbo page which use the Turbo-SJ50 combination.
In aerobatic type aircraft, you may have to relieve the cowl a bit to allow clearance for part of the muffler.
As for other options, the Bisson mufflers seem to work fairly well in some applications, but there is a performance loss. It is important that the engine have adequate back pressure, and you still must prop it to run in the specified RPM range.
I hope this has been helpful.
Bob Brassell
Bob Brassell
