Dub Jett Engines Support Bob Brassel of Dub Jett Engines provides direct support here for Jett Engines.
Sport Jett 46 prop
Reply
Old 08-06-2002, 03:36 AM
Spraytec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sport Jett 46 prop
Broke in my Sport Jett 46. Now I need advice
on prop for Hi speed runs in Whiplash Delta.
Plane is approx. 3 3/4lbs, I am using the stock muffler (red.
Maybe APC pylon ? 8.8 in with 8.75-9.25 pitch? Wildcat 15% nitro
Spraytec is offline
Old 08-06-2002, 11:14 AM
bob27s
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Mike.....
there are a variety of combinations you can try.
I would say to start with a standard APC 9x7, and perhaps then try an 8.8x8.5 pylon prop or the 8.75x9W. Try and keep the SJ-46 engine in the 17K rpm (peak, on the ground) range... or slightly above. You can keep adding pitch as long as you stay in that rpm range. Another prop that works pretty well is the 8.5x7.25 pylon prop. The engine will really turn that sucker, and it will unload big time in the air.
You may also want to post the question in the Extream Speed forum. There is quite a bit of experience in there
http://www.rcuniverse.com/forumdisplay.php?forumid=162
I trust this will be helpful.
Bob
bob27s is offline
Reply
Display Modes
