Jett 1.5" spinner
Jett 1.5" spinner
Im looking at replacing the 1.5" Tru-Turn spinners with a Jett 1.5" on my 21 size pylon models because the Jett profile shape works a bit better.
- will the Jett backplate accomodate a 1/4 x 28 tpi crankshaft end?
- is there a typical insert ring that allows different (smaller) crank diameters?
- does the locknut/washer come with the spinner set?
- does one spec the locknut thread at the time of ordering or is it even available in different flavours?
- what is the approx weight?
Thx
Thx
My Feedback: (19)
OH
RE: Jett 1.5" spinner
ORIGINAL: ptxman
Thx
Thx
Each spinner includes all of the hardware.
I will have to check on the weight ..... but they end up lighter or equal to a tru-turn equivalent.
What engines are you running? If they are collet mounted drives it might be worth asking if Dub can cut the backplate to fit the locking collet on your engine. [email protected]
Bob
Thanks for the info. I understand now, the Jett spinner is machined with the same integral washer/spinner backplate like Q40/Q500 engines. The Novarossi (and other 21's we race) is the typical drive washer that fits over a tapered collet. Yes, Ill have to contact Dub with dimesnions & inquire.
My Feedback: (19)
OH
ORIGINAL: Broken Wings
Is a puller required to remove the Jett drive washer? I haven't tried to remove the prop drive yet but I need a 2.25" Spinner for a 60LX.
If it gets stuck used the handle of a screwdriver, and just quickly hit it on the prop-drive surface of the drive. Same goes for removing the integral spinner too.
