Dub Jett Engines Support Bob Brassel of Dub Jett Engines provides direct support here for Jett Engines.
3 way valve with Jett tank
Reply
Old 07-16-2008, 07:14 PM
Broken Wings
My Feedback: (20)
Broken Wings's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 3 way valve with Jett tank
I just learning about the Jett bubbleless fuel tanks as I want to try one. Can a 3-way valve be used to fill the tank using the Jett Fueler?
Broken Wings is offline
Old 07-17-2008, 11:33 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 3 way valve with Jett tank
Hi,
Thanks for writing......
Interesting valve. That one probably would be ok to use with the fuel system. As long as it does not leak under suction or pressure you are ok.
I suggest that most folks avoid the poppet-type fill valves, since they have sometimes caused issues. I have used those in the past with some success, but I have also has issues too.
The best way to use the bubble-jett tank is to avoid any additional connections other than perhaps putting a joiner or fuel filler in-line going to the engine. This image shows how I did it on my Edge. Just a quick in-out setup at the cowl with a joiner in the middle.
http://www.jettengineering.com/engines/bse40.html look at the red Edge image about half way down the page.
Bob
bob27s is offline
Old 07-17-2008, 03:43 PM
Broken Wings
My Feedback: (20)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The one shown is sold by Central Hobbies, they've got a couple different types of them.
When you say joiner do you mean a “T” fitting with a fuel dot or just a double barb fitting so the tubing can be separated more easily?
Old 07-18-2008, 11:57 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
in-line double - not a T
You can not evauate the tank with a T-fitting - it will try to draw air from the engine side too (unless you somehow clamp off that branch of the fuel system)
bob27s is offline
