Dub Jett Engines Support Bob Brassel of Dub Jett Engines provides direct support here for Jett Engines.
Jett Muffler - Performance Decrease With Deflector.
Reply
Old 07-18-2008, 02:16 AM
PlaneHeli
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Jett Muffler - Performance Decrease With Deflector.
I have purchased two Jett Red Tuned mufflers for my OS 46AX and OS 55AX engines.
I see silicone exhaust deflectors have been used with your mufflers.
What sort of power decrease (if any) could I expect to see using silicone exhaust deflectors.
I noticed you recommended an internal diameter larger than the exhaust outlet. I would fit one as you recommended.
Cheers
PlaneHeli is offline
Old 07-18-2008, 11:55 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Jett Muffler - Performance Decrease With Deflector.
No effect on power output or performance.
You want a tube that has an inside diameter that slips over the tail piece on the muffler. Then secure it with a thin zip tie. Try and keep the length to a minimum.... under 2.5" is a good target.
Typically the 40-90 size deflectors from Great Planes and Dubro work ok. You would want to avoid anything much longer than that.
bob27s is offline
Old 07-18-2008, 06:46 PM
PlaneHeli
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks bob27s.
Will do.
