Dub Jett Engines Support Bob Brassel of Dub Jett Engines provides direct support here for Jett Engines.
SJ .50 & 'smoke-0n'
Reply
Old 09-02-2008, 11:52 AM
JT Hammer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default SJ .50 & 'smoke-0n'
I am putting a Phoenix F-20 together (nice ARF except for some of the hardware which I am replacing). I intend this bird to be a reasonably quick - but just a nice sport-plane. Thought it would be kool to have a smoke system but know little about hooking one up. So can anyone help me out? Questions: Does the jett .50 lend itself to this application?
What mods are required to the engine/muffler (i.e.pressure taps and
where)?
What parts needed? (valve. tank, smoke fluid)
Where to purcahse above?
Is it worth it (enough smoke)?
Anyone done it with a prop jet?
Also, re this airplane and the SJ .50. I will break the engine in on a smaller prop i.e. apc 9/7 but was planing on flying with a 10/6. Based on reading other remarks in the forums, I'm thinking maybe a 9/8 might be preferrable...or would they be about the same? Anyone have experience with this f-20 and engine combo and what prop?...............JT
JT Hammer is offline
Old 09-02-2008, 11:58 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SJ .50 & 'smoke-0n'
In a few words..... skip the smoke. It does not work well with the jett muffler.
Start off flying it with the 9x7.... work your way up to a larger prop you become familiar with the engine and aircraft.
The 10x6 will give you a very good balance of performance. The 9x8 will give you a bit more level flight speed.
If you are running fixed gear (stock setup), go with the 10x6.
bob27s is offline
Old 09-02-2008, 05:09 PM
JT Hammer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks - then I will skip the smoke; less hassle anyway! I'll likely fly with the 10/6 prop since I am leaving the fixed gear on. No one flys very fast models in our club, so my f-20 will look pretty quick anyway. It's all relative!..............JT
