Dub Jett Engines Support Bob Brassel of Dub Jett Engines provides direct support here for Jett Engines.
Jet 50 FIRE remote needle valve
Reply
Old 02-08-2009, 02:33 PM
ke6gkc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Jet 50 FIRE remote needle valve
Hey Bob,
I have a new 50 FIRE with remote NV. My question is can I convert the carb to standard NV location at carb or do I need a new carb?
If I can what are the parts required?
Just so you know the engine is going on a Screamin' Demon and no place to mount remote.
Thanks Bruce
ke6gkc is offline
Old 02-09-2009, 01:30 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Jet 50 FIRE remote needle valve
ORIGINAL: ke6gkc
Hey Bob,
Thanks Bruce
Hi Bruce....
Dub does not offer a front-needle carb. Has not have one available for r/c use for several years.
The remote needle can be mounted pretty much anywhere. Airframe mounted is prefered, or you can keep it mounted to the engine. You may orient it in any position.
This image is a bit small, but you can see where Chuck mounted his needle - it is mounted on the top surface.
Probably a better way to mount it would be to place it behind the "Firewall" mounted veritical or at an angle coming off to the side.
Bob
ID:	1131364   Click image for larger version
bob27s is offline
