Dub Jett Engines Support Bob Brassel of Dub Jett Engines provides direct support here for Jett Engines.
Jett Radial mounts
Reply
Old 04-01-2009, 09:26 PM
Broken Wings
My Feedback: (20)
Broken Wings's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Jett Radial mounts
Jett 90L powered GP Big Stick 60....
The 3 hole Jett radial mount worked out GREAT!!!
The black disc is a chunk of Delrin that I machined to accept the stock blind nut hole locations on the ARF. The Jett mount bolts up to the Delrin disc and also allows me to run the Fults nose gear.
I bought a roll of the Graupner control surface tape as well....
I hope I don't break it....................
ID:	1170922   Click image for larger version
Broken Wings is offline
Old 04-07-2009, 06:53 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Jett Radial mounts
Nice !!!
Make sure the firewall is on there well, and ensure that the fuel tank is padded all around. Should be a heck of a good flying machine
bob27s is offline
Old 04-23-2009, 08:21 PM
Broken Wings
My Feedback: (20)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Engine is mounted horz.
The hatch is 1/8th balsa and just glued on the ARF. I cut the hatch out/off and will replace it with ply after I beef up the firewall. There is also a thin bulkhead that supports the "proprietary" fuel tank. You're stuck using the GP tank unless you remove it.
I bought a Hayes 16oz slimline. Per your instructions I'll be able to pad the tank all over with 1/2" foam rubber. I hope I don't have any fuel tank issues.
What's you best guess "run time" for a Jett 90L on 16 oz's?...... wot
Old 04-28-2009, 12:32 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry for the delay responding......
the 90L at full song burns just under 2oz per minute. Figure you have 7-8 min, but throttling back part of the flight really can extend that
Bob
bob27s is offline
