Dub Jett Engines Support Bob Brassel of Dub Jett Engines provides direct support here for Jett Engines.
Jett BSE .50 & Fuel
Old 06-16-2009, 03:08 AM
emh888
Default Jett BSE .50 & Fuel
Hi,
I bought Jett BSE .50 & the problem I cannot find a nitro fuel with castor oil, the best fuel I can buy is the coolpower 15% nitro + 18% Synthetic Oil so should I add castor oil into the fuel? If yes which castor oil do you recommend and how much quantity should I add to 1 Gallon.
Old 06-17-2009, 10:17 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Default RE: Jett BSE .50 & Fuel
If all you can find is the coolpower, then run that. No issue, the engine will run just fine.
Just be sure to set the needle correctly - error on the slightly rich side.
If you can find good Sig, Baker or other de-gummed racing castor oil, add just 1.5oz to the coolpower. A little goes a long way.
