Dub Jett Engines Support Bob Brassel of Dub Jett Engines provides direct support here for Jett Engines.
Jett engine cleaning
Reply
Old 07-30-2009, 12:57 PM
jplavoie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Jett engine cleaning
Hi,
I burned about 10 gal of fuel with my BSE 76L and its head is now covered with baked castor oil. I never had this problem before as I use to run with synthetic oil. I fear this gummy layer reduces the cooling and and make the engine run hotter. Is it necessary to clean the engine (if yes, please let me know how) or this is nothing to worry about.
thanks
JPL
jplavoie is offline
Old 07-31-2009, 11:08 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Jett engine cleaning
Thanks for writing.....
in general, the varnish does not affect the engine much. But cleaning it is not a problem either.
The fins are just the "Head clamp " .... the head button is a seperate piece. So no issue with removing the fins and cleaning them. The hot anti-freeze method works ok, and perhaps follow that with a buffing wheel to make it shine again.
I do not recommend cleaning any internal parts like the head button or piston.
Also...... we recommend a little bit of castor in the fuel. Usually that is only 2% or so..... generally does not make that huge of a mess. Main reason for this is to provide a little protection to the engine, especially for folks running an ABC engine for the first time.
Worth noting though, since the engine has time on it, and you are use to the way it operates ...... using 100% synthetic fuel is ok.
Bob
bob27s is offline
