Dub Jett Engines Support Bob Brassel of Dub Jett Engines provides direct support here for Jett Engines.
QM-2 Set-up
Old 04-08-2010, 05:41 PM
Frequentcrasher
Default QM-2 Set-up
Hi, I just received a QM-2 40 and am wondering about the set-up. Does the backplate go on, then the insert into the backplate, then prop, then washer, then spinner adapter? Or do I have the order messed up?
Old 04-10-2010, 08:20 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Default RE: QM-2 Set-up
the spinner mounts on the tapered shaft collar. So it is usually easier to put the prop stud on first, then install the backplate. You need the prop installed to keep it in place.
Bob
Old 04-13-2010, 10:40 PM
Frequentcrasher
Thanks Bob,
One more stupid question before I fire it up. Does the little hole in the counterbalanced backplate point up when the intake is fully open like a nelson?
Old 05-01-2010, 06:47 AM
bob27s
My Feedback: (19)
bob27s's Avatar
yes, should be the same
