Jett 60 LX
Ok I ran two 16oz tanks thru my 60LX yesterday and wow, impressive, I ran it with a 9x7 APC at 16000 to 17000 for both tanks,it was still rich too, does that sound like the instructions say, or close to it, for break in, now what, shoiuld I run a few more tanks thru it the same way, or lean it out a little more?
Thanks for the help, I just want to do it right.:D |
RE: Jett 60 LX
You want the engine to peak over 17,500 ground rpm. So looks like you are on the right track.
It is good to fly...... find peak rpm, back off 800-1000 rpm from there...... (should be around the 17,000 slightly rich you noted), and you are good to go. Best thing you can do now is fly it. Error on the rich side, and lean it slightly from there if needed. |
RE: Jett 60 LX
Thanks Bob, for the info.
