charge rate
charge rate
Hi,
I have a turngiy nano-tech 2.2mAh 4c 25 - 50 discharge high discharge lipo battery
it says on it max charge 5c
what does this mean with regards to charging it
thanks,
Gary
thanks,
Gary
My Feedback: (325)
RE: charge rate
Your may mean 2.2 ah (rather than mah) and you might also mean 4S? (rather than 4c)
Anyways , 5C means charging at 5 times the "C" or 5 times the capacity. If your capacity is 2.2 ah then that means 2.2 x 5 = 11 amps.
RE: charge rate
Thanks mate,
you are of course correct in your corrections, once again thank you from a numpty when it comes to electrics, by the way have you any experience with the above named battery
thanks
thanks
My Feedback: (78)
FL
RE: charge rate
Following these charge rates I have never had any problems with any of my batteries and you also have to keep in mind I have over 150 cycles and they look new still (no puffiness) and still have the punch power.
