E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
20C 2000mAh 3s1p 11.1V - Help Charging?
Reply
Old 03-28-2011, 10:15 AM
artistic-aero
artistic-aero's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 20C 2000mAh 3s1p 11.1V - Help Charging?
I have just got into electric flight and with the aircraft I bought came two batteries:
AirPower 20C Range 2000mAh 3s1p 11.1V
I am not sure how to charge these, I have a dedicated LiPo charger and a balancer, the charger is set up manually and requires a variety of settings most of which I understand.
Its the charge rate I want to get right, I set it at 2.0Ah and it took almost overnight to charge. I wouldn't mind a slightly faster turn-around, any ideas?
artistic-aero is offline
Old 03-28-2011, 01:26 PM
guver
My Feedback: (325)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 20C 2000mAh 3s1p 11.1V - Help Charging?
2.0 ah is the capacity of the pack. A rate of current is expressed as amps and could have been 2 amps? If so then by definition it shall deliver 2000 mah in 1 hr. If it took overnight then maybe it was really set to .2 amps (200 ma) of current.
A lot of people like to use the 1 hr charge and for your pack would be 2 amps.
guver is offline
Old 03-29-2011, 11:16 AM
Glacier Girl
Glacier Girl's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep as guver stated, it sounds like you charged at .2 amps instead of 2.0 amps.
And leaving a pack charge overnight/unattended isn't a good thing to do with a lipo.
If something goes south on you, you won't know until it's too late.
Glacier Girl is offline
Old 03-30-2011, 05:31 AM
artistic-aero
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It was charged at 2.0 alright, double checked. It was also passed through a balancer, I'm wondering if that's the problem, charged again without the balance and the job was done in 1 hour and 11 minutes, though the battery checker showed 88%. I also use a power supply, a 200w device that is clearly up to the job according to the instructions.
I'm wondering if the batteries are duff. I charged one of my shockie batteries on the same system and they were done on time and full charged. I'm going to charge the same set on another set-up and see what happens.
The LiPo was charged in a very safe place, could have blown up and caught fire if it wanted to without harm to the surroundings.
Thanks for the help.
Old 03-30-2011, 01:38 PM
guver
My Feedback: (325)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm guessing here: the pack was charged in an hr or so , but just didn't turn off for some reason.
Remember by definition 2 amps = 2000 mah (in 1 hr)
guver is offline
Old 04-05-2011, 03:43 AM
artistic-aero
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, thats about what I was asking in the beginning, the pack was charged at 2.0 through a balancer and took 16+ hours and discharged in under a minute. I then removed the balancer and it was charged in 1 hour and a bit. The pack discharged in... just under a minute. So I borrowed another battery pack and that discharged in 8 minutes. I then recharged it through the same set-up without the balance and it took 1 hour and a bit and discharged again in 8 minutes. I'm guessing the batteries are duff. Next step is to use the balance. I have a feeling all will be well there again. Guess its process of elimination and process of buying-more-batteries. Hurray!
