E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
hobbyking accucel 6
Old 04-30-2011, 04:42 AM
smallbigblob
Default hobbyking accucel 6
Does anyone have a hobbyking accucel 6? If so, how do I charge a Turnigy 2s nano-tech lipo seeing as though the plug from the battery is different from the cable supplied with the charger? Usually when charging my 6s batteries i connect both the jst plug and the power cable to the charger. Is it necessary to plug in both the cables when I charge the nanotech battery? Included is a photo of the battery. Sorry if i confused anyone with my question.
ID:	1601323   Click image for larger version
Old 04-30-2011, 04:48 AM
mike79
Default RE: hobbyking accucel 6
I have the accel. When charging those I put two wires in the end of the connector and use the aligator clips with the charger until I make a harness. You dont have to use the JST but I would for data and to balance charge.
Old 05-07-2011, 04:37 AM
smallbigblob
and why didn't i think of that earlier. cheers mate!
