E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Parkzone F4u and Power 15
Reply
Old 06-22-2011, 05:21 AM
ads8525
My Feedback: (34)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Parkzone F4u and Power 15
For those of you that have done this upgrade, if I were to upgrade to a power 15 on my Parkzone Corsair, what flight times am I looking at for a 3s, 2000mah battery? Are you guys using a 3s or 4s battery?
ads8525 is offline
Old 08-03-2011, 07:26 PM
mark50b
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Parkzone F4u and Power 15
A 3s will work, but to get the most out of the Power 15, a 4s lipo is a must.
mark50b is offline
Old 08-04-2011, 04:30 PM
Swift427
Swift427's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: mark50b
AGREE!
Going from an 1800mAh to a 2000mAh when converting from the 480 960Kv outrunner to a Power 15 that can consume up to 575 watts when using a larger prop will drastically reduce your flying time unless you are relatively speaking a conservative pilot. IF that were the case then there's no sensible advantage to upgrading to a Power 15, UNLESS you want to do just a few bursts of unbelieveable show-off performance and then resume flying for the majority of your flight time as if you still had the 480 outrunner. The other thing is upgrading your stock 30amp ESC to handle the Power 15's thirsty appetite without frying the 30amp ESC. And a 3S LiPo with at least a 25C discharge rating. Even then I'd think you'd shorten the life of a 3S when drawing 575 watts for even a few seconds from a 60amp ESC.
A 4S LiPo is a MUST! with a Power 15 assuming you are going to give your bird a real workout.
Swift427 is offline
