Li-Polys for Mega
Li-Polys for Mega
Yes, you can use them in any Mega motor. Pick a cell that you like and then design your pack based upon needed current delivery and flight time.
Good luck!
Good luck!
Li-Polys for Mega
As an example, the Mega 16/15/4 can draw up to 25amps so you need a pack that can handle that current level reasonably well.
A Kokam 1200HC cell can supply 6amps continuous and a 3s pack will give you a voltage similar to a 10-cell NiCd pack.
A 3s pack weighs about 3oz and a 3s4p (4 packs of 3s in parallel) will provide 24amps continuous at a weight of about 12oz and have a total capacity of 4800mAh.
Compare this to a 10-cell CP2400 pack at 21.6oz.
The Lithium pack weighs almost 10oz less and provides twice the flight duration!
The bad news is that the Lithium pack costs about $210.
