E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Lipo & Bec
Old 08-20-2003, 09:11 AM
Pucara
Default Lipo & Bec
Can the BEC @ 5v ruin a package of 2s1p batteries?
Pucara
Old 08-20-2003, 10:49 AM
Matt Kirsch
My Feedback: (21)
Matt Kirsch's Avatar
Default Lipo & Bec
Sometimes people get BEC and LVC, the low voltage cutoff, mixed up. The BEC has nothing to do with shutting the motor off when the battery voltage gets too low; it simply regulates the battery voltage down to 5V to power the receiver and servos.
If you really meant LVC, then yes, it will damage a 2S1P LiPoly pack if you run the motor down to LVC. There are a few ways to avoid this, though:
1. Time your flights. To figure out how long you can safely fly, fly for a while, land, measure the voltage on the battery, fly some more, land again, measure voltage, and so on. Make sure you use a stop watch to measure how long you've flown.
2. Pay attention. When the power starts to drop off noticeably, land.
3. Get an ESC with a programable LVC. There are some LiPoly-specific ESCs out there, but the Castle Creations line has always been programmable in that respect. Program it for 3.0V per cell, or as close as you can get to that value.
Old 08-20-2003, 11:02 AM
Pucara
Default Lipo & Bec
Matt,
Thank you for your kinldy answer. I really did not know there were besides BEC LVC. Here in The Netlerlands Schulze Controller is popular, Castle Creations not. I will take your advise of messuering the Volts.
Best regards,
Pucara
Old 08-20-2003, 02:11 PM
e-bird
Default Lipo & Bec
Bec battery elemator circuit just a voltage regulator that doesn't
produce RFI rdaio freq interfance.
http://www.national.com/catalog/AnalogRegulators.html no big
thing in elec but models make issue of it build a better one than you can buy . I have several ctrl's and some of the also produce
RFI the newer OPT coupled seam to be better. CU
Old 08-27-2003, 11:34 PM
BEC
Default Lipo & Bec
For more info about this, see my column on the Ezone: http://rcgroups.com/links/index.php?...at=210&id=4234
Old 08-29-2003, 06:52 PM
Greg Covey
Greg Covey's Avatar
Default Lipo & Bec
There you have it.
"Lipo & Bec" by BEC
