E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Triton EQ- Problem charging 5 cell NiMh Pack
Reply
Old 09-20-2011, 03:47 PM
stunt-man
stunt-man's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Triton EQ- Problem charging 5 cell NiMh Pack
I am having a problem charging 5 cell NiMh cells using my Triton EQ charger. The charger never reaches the end of the charging cycle and then goes on tricle charge. This seems to happen with 5 cell packs.
Anyone else having this problem
stunt-man is offline
Old 09-20-2011, 05:04 PM
guver
My Feedback: (325)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Triton EQ- Problem charging 5 cell NiMh Pack
As far as I understand the Triton EQ , it only goes to trickle after the end of a peak charge, right?
It does display end of charge data like capacity and time. Are those readings normal?
guver is offline
Old 09-21-2011, 03:40 AM
stunt-man
stunt-man's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Voltages and time indicate that the pack is fully charged. The charger then doesn't indicate "end of charge" and go to trickle as is the normal case in the normal charge cycle. This problem only surfaces with 5 cell NiMh packs. Anyone else experience this.
Old 09-21-2011, 04:20 PM
guver
My Feedback: (325)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Could it be that the trickle is ONLY available on NIcad and not NIMH. Maybe NIMH get a 20 minute top-off?
Upon checking the manual it is addressed on pg 6 and 7 (kinda) It apears they make no distinction between NItypes and I don't see where a "trickle" message will apear. Only an "end" message with a trickle charge being applied until removal. I assume the fast charge does end , yet the trickle isn't happening.
guver is offline
Old 09-22-2011, 03:43 AM
stunt-man
stunt-man's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, the fast charge doesn't end. It just keeps charging.
Old 09-22-2011, 02:09 PM
guver
My Feedback: (325)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, that makes it more interesting and a different approach to diagnosis.
I suppose the question then to ask is does the pack overheat and/or does the voltage start to drop toward the end? I'm gonna guess that the pack is so very close to full that the charger will shut off if allowed to finish. Chances are that if you had left it go it would've stopped within minutes (unless the pack is already overheating and voltage is dropping more than 50 mv)
guver is offline
Old 09-22-2011, 03:43 PM
stunt-man
stunt-man's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The battery is past full charge. I'm really looking for comments from people using a Triton EQ who charge a 5 cell NiMh.
