If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 8 of 8
Thread: "C" rating
  1. #1
    Join Date
    Jul 2007
    pembroke pines, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    "C" rating
    I'm going to fly a new type of plane at full throttle most of the time. Is it better to have a higher or lower C rating (ie: 25 C or 35 C)
  2. #2
    Join Date
    Mar 2003
    LaGrange, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    It depends what result you want and how close to the actual "C" rating you are.
    If you want max power and/or if you are operating very close to the max "C" then use the highest actual "C" , if you want lower performance, long flight time and soggy performance and are operating well below the max "C" rating then choose the lowest "C" rating acceptable.
    Probably the answer is simply to use the highest "C" rating , it won't hurt anything to go too high in "C" number. I know you already said you'd use WOT , but another thing to consider is that using a higher "C" rated pack may allow you to use LESS throttle to get the same power.
    and airplanes were in
  3. #3
    fmw's Avatar
    Join Date
    Apr 2010
    , IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    The only downside to a higher C rating is some added weight.  The C rating has nothing to do with flight time.  The prop and motor will try to draw all they need.  If they can't get it, then some of the power is lost in heat.  If they can get it, then the power will go to the prop.  More is better and more is also heavier.
  4. #4
    Join Date
    Jul 2007
    Warner Robins, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    The higher the "C" rating, the lower the battery's internal resistance. If you have a speed control and motor that can draw 60A, then the lipo ideally should be capable of delivering close to twice that current.
    So, a 3300mah battery rated at say 20C can supposedly provide a maximum current of 66A, and is less than recommended for a 60A motor and speed controller. A 30-35C battery is much better. (99-115)
    A 25C 3300mah battery can deliver 82A.
    Remember that the C rating should not be considered a continuous rating if you plan on using the battery more than a few times.
    The typical (for me) use - -
    Take off 4s 3300mah Lipo Max current is limited to either 60A due to the speed control, or up to about 80A (battery & speed control combo)
    As soon as the plane is in the air and stable, power is reduced, to just above 1/2 throttle for normal flying. This usually results in 5 to 6 minute flying times without overly discharging the battery.
  5. #5
    Join Date
    Jul 2007
    pembroke pines, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    Thanks for all the useful info, guys.
  6. #6
    Join Date
    Jul 2007
    pembroke pines, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    Okay that clears some things up for me. The plane comes with a 55 amp ESC so doubled it can handle 110 a. According to an earlier post the zippy 4000/25C (100a) will work good in the plane for both the w/b and output. I would also like to try a 3600/30C (108a) and a 3300/35C (115a). The extra 5a won't cook anything will it?
  7. #7
    Join Date
    Mar 2003
    LaGrange, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    It seems as though you are thinking that the battery forces 100 amps thru to the esc and motor. It doesn't work that way , but rather the motor pulls whatever it requires from the battery. So, it is impossible to size the battery too big. Put a 1000 amp capable battery on and the motor may only pull 50 amps or whatever it wants.
  8. #8
    Join Date
    Jul 2007
    pembroke pines, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    That sheds some more light where needed. Thanks, Guver
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
