Looking for lipo discharge data.
OR
Anyone know of any discharge graphs or data for Etec1200's @ 7C discharge ?
Any info would be greatly appreciated.
We are testing some new lipoly's at the moment.
Here is what I got on one test:
New 1200mah cell. (not etec)
7C discharge (well 8 amps so close).
cut off votlage was 3 volts. Manufacturer claims 2.5 volts is safe.
Pack put out 1050mah during this discharge until 3volts was hit.
So if I did everything correctly the battery @ 7C got 87.5% capacity. If I am not mistaken that is good. right? Had I taken it to 2.5 volts I am sure battery would have gotten 100% @ 7C.
Will test cell @ 10C next.
Anyway more to come later in a new thread. need data to test against.
Mike
Mike
RE: Looking for lipo discharge data.
Is that 2.5 volts bottom under load or idle I don't think it's idle about 3.5 to 3.7 idle about 15 min after flight a lot of money for a few min of flight.
http://www.unipros.com/battpacks/mai...ssion_id=48633
Has a new line of batterys I have 12 on the way a lot cheaper than some with the same spec's > CU
I found a graph of the Etecs discharged at 8 amps on another web site.
http://www.rcgroups.com/forums/showt...40#post1039440
Hope that helps.
Hope that helps.
This site has 6C and variable 6-10C run for E-TEC 1200
http://www.rinninsland.de/modellbau/akkus/
This site has many different C's up to 20C run for kokam 340HD, 640HD and 2000HD
http://www.schuebeler-jets.de/
Esa
Esa
