E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Receiver batteries
Reply
Old 08-09-2012, 04:40 PM
heritageman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Receiver batteries
When using two receiver batteries, do I just wire them parallel. Both are exactly alike.
heritageman is offline
Old 08-12-2012, 09:35 PM
chuckk2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Receiver batteries
It's possible. The concern is to make sure that both are at the same state of charge when connecting them in parallel.
Otherwise, the weaker will draw from the stronger, until they are equal in charge. It's usually better, at least in principal. to use larger capacity single battery packs. If the battery pack output voltage has enough "margin", diodes can be used to "decouple" the battery packs. The diodes must be identical, have a low forward resistance, and appropriate current and voltage ratings. However, as the parts count goes up, the chances of failure also increase.
chuckk2 is offline
