Go Back  RCU Forums > Electric Aircraft Universe > E-Flight Power Sources
Reload this Page >
where to place the crimp seam on anderson power pole pin
E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Reply
Old 10-08-2012, 03:47 AM
suzonka
My Feedback: (7)
suzonka's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default where to place the crimp seam on anderson power pole pin
I CANT FIND A GOOD PICTURE OF WHERE TO PLACE THE PIN SEAM WITH A PLIERS TYPE CRIMPing tool USING
ANDERSON POWER POLE PINS .15 or 30 amp pins
suzonka is offline
Old 10-08-2012, 11:02 AM
jbdismukes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: where to place the crimp seam on anderson power pole pin
I read on some other forum that the poster got best results by placing the seam in the curved portion of the pliers. I solder mine.
Jack
jbdismukes is offline
Old 10-08-2012, 01:28 PM
guver
My Feedback: (325)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you're asking about how to orient the connector pin in the pliers then just look at the die , it should be very clear and only goes in one way.
If you're asking about which way to orient the connector into the plastic housing then the split goes toward the wide part of the housing.
If you are using any regular type crimp pliers then put it in same place as any other regular type crimp connector.
guver is offline
Old 10-08-2012, 02:42 PM
suzonka
My Feedback: (7)
suzonka's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
as in this picture if its right because I have seen other pictures of it being opposite in the placement of the seam should it be like in this picture with the seam facing the little bump in the tool?
[img][/img]
suzonka is offline
Old 10-08-2012, 02:48 PM
guver
My Feedback: (325)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is the wrong tool , but it can go either way if you use that regular crimp tool. Hopefully it won't deform the end. I kinda like you way as opposed to the opposite way.
guver is offline
Old 10-08-2012, 03:14 PM
suzonka
My Feedback: (7)
suzonka's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: guver
So the answer for that type of tool is either way ,thank you
suzonka is offline
