E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Charging small 1s LiPo with a "proper" charger
Reply
Old 03-18-2013, 01:46 PM
ghost123uk
ghost123uk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Charging small 1s LiPo with a "proper" charger
Hi all,
I have a couple of Ultra Micro models as well as my bigger ones. These use the tiny "Celectra" plugs directly attached (no wires) to the cell and come with a very basic charger. Also this charger runs off 4 x AA cells [X(] or a 6 volt input, so not ideal there either (compared to normal 12 volt field chargers)
I do own a decent "proper" LCD equipped field charger that will go down to 1S at as little as .1 amp, but I cannot find a "female" adapter to enable me to connect them to a normal "proper" charger.
This would also give me an accurate voltage reading in the field as well as 12 volt input.
I am in the UK and cannot find a Celectra socket / lead to fit the plug attached to the LiPo []
Is anyone else using a "proper" charger with these tiny LiPo's ?
ghost123uk is offline
Old 03-18-2013, 02:15 PM
Bluelt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Charging small 1s LiPo with a
Yes, use a proper charger with a charge cord like the one here;
http://www.valuehobby.com/accessories/charge-discharge-wires.html
You can do a search on how to charge multiple batteries.  With one battery hooked up you will see a voltage value!
Bluelt is offline
Old 03-18-2013, 02:31 PM
ghost123uk
ghost123uk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Although I am in the UK, your suggestion was very helpful as it helped me find a similar cable on UK ebay ([link=http://www.ebay.co.uk/itm/XTREME-Charging-Cable-for-3-MCX-MSR-1S-LIPOs-/261120430359?pt=UK_ToysGames_RadioControlled_JN&hash=item3ccbfd9117]LINK[/link])
Not sure I will use it for parallel charging of LiPo's though ([X(]), but it will do what I need it to
